Old 04-24-2006, 04:08 AM
Default I need FE cam retainer plate bolts
Anyone know where to get some? I take that you could use an off the shelf bolt somewhere...just as long as it clears the timing gear, right?
Old 04-24-2006, 05:08 AM
Clois Harlan's Avatar
Brent,
Are you talking about those 1/4 X 28 or 5/16 X 28 phillips head bolts? If so I have seen engines that use a six point low profile bolt to hold the retainer.
Clois
"Let's roll"
"Be part of Something Good
Old 04-24-2006, 05:34 AM
Yes...the phillips head screws that hold the retainer plate on. I may have to look for a thin head bolt.....
Old 04-24-2006, 05:36 AM
www.dscmotorsport carries ARP bolts for this purpose that have been clearanced. The website says they are 7/16-14 x 3/4. Seems a little large....I was thinking they were 1/4 or 5/16 myself.
Old 04-24-2006, 07:24 AM
www.dscmotorsport.com
...above link was missing the dot com thingy...
Old 04-24-2006, 07:43 AM
Thanks Ernie.
Old 04-24-2006, 09:09 AM
Rick Parker's Avatar
Flat head countersunk internal hex head machine screws work real well, they are generally made of pretty good material. You may need to countersink the holes in the plate itself, but the finished installation will turn out real nice, with plenty of clearance. This is what I used myself. They are available at many hardware and farm impement type stores.
Old 04-24-2006, 09:26 AM
Thanks Rick!
Old 04-24-2006, 09:27 AM
Just be sure to use Red Locktite.
Old 04-24-2006, 11:17 AM
Permanent? Would I be able to get them back out if need be without shearing them?
Old 04-24-2006, 11:41 AM
Sure, the red Locktite is just higher strength. I use it exclusively. If needed a little heat like from a propane torch for a moment will release the Locktite, but usually it is not needed, just a little additional effort. I just like the additional insurance of the "Red" Locktite. For that matter I use it on all chassis & engine fasteners except Rods, Mains, Head Studs/Bolts. Getting the screws out is not a concern.
Old 04-24-2006, 02:10 PM
lineslinger's Avatar
Hey Rick is that your cat on top of the telephone pole / transformer?
Old 04-24-2006, 02:38 PM
Powers on!
Old 04-24-2006, 07:36 PM
I use button head allen bolts.
Easy to get - at least around here.
Maybe I need to add them to my site for a few bucks/set...
Barry R.
Survival Motorsports
Old 04-24-2006, 10:11 PM
Button head allen bolts are carried by most hardware stores.
Old 04-24-2006, 10:30 PM
RedCSX1's Avatar
Default Do Not Use Red Locktite!
NEVER GET THEM OFF AGAIN, USE BLUE
Morgan LeBlanc
Fresno CA
Old 04-24-2006, 10:44 PM
Especially when using button head bolts, I've got to agree with RedCSX1's insistance on using blue loctite. Button Heads have a smaller hex in them, making it easier to deform the bolthead when removing them.
On standard grade 8 or better bolts I use red loctite, as it's easier to remove than you realize. However, the blue stuff would probably work as well.
My 2 cents,
Dan
