Old 05-04-2006, 05:35 PM
Default My block is here! Thanks KC!
I received my block today from Keith Craft. It's exactly what I wanted. The detail that's in this block is impeccable. I'll try to get it on the stand and take some pictures tomorrow.
It's a C5AE-A 390 block. It's a webbed main block and had the nubs for cross bolt caps. Keith sonic tested it and found it to be as thick as some of his 428 blocks, so he bored it to a 4.130" bore. It has been bored, square decked, align bored, cam bearings installed, all oil passage work completed, press in plugs were changed to screw-in pipe plugs, main bearing oil holes were chamfered, it was cleaned, painted and glyptol'd....and here's my favorite part: the block was milled to accept my Pro-Gram billet cross-bolt main caps. This block looks so stout on the bottom end. I'm going to be pushing 600hp and will be turning 6500-7000 revs....so I wanted the extra beef.
I'll be using a new Scat 3.98" stroke crank....so I'll basically be working with a 428ci FE.
I took off tomorrow so I could play with my new toys. I'm gonna bolt the tranny and bellhousing to the block along with the motor mounts and set it in the car. I need to make sure that it will set in the same place as my small block and have plenty of clearance between my fabbed valve covers and the footboxes.
I've already blueprinted my crank.....and I'm gonna try to bore mic the main and rod bearing ID's tomorrow.
Thanks again Keith. You and your shop do excellent work.
My wife won't let me keep it in the living room tonight.
Old 05-05-2006, 06:46 PM
Here's some pics....
http://www.network54.com/Forum/74182...block+from+KCR
Old 05-05-2006, 07:12 PM
LMH's Avatar
LMH LMH is offline
That's really sweet looking Brent! KC sure does nice work.
Old 05-05-2006, 07:33 PM
Thanks Larry....hopefully I won't screw it up by putting a big "ventilation" hole in the side of it.....hehehehe
Old 05-05-2006, 07:58 PM
Buzzmobile's Avatar
Cobra Make, Engine: SPF 148 with 427 SO
Hey there....can you help me with a pic of the trans end of your crank? I need a pic for comparison. Was looking for one without the pilot bushing installed....
thanks
Buzz
Old 05-06-2006, 05:08 AM
Buzz, I've already got the bushing installed....sorry....
What were you needing to see? I can describe what's behind there if it would help....
Old 05-06-2006, 10:52 PM
Thumbs up
Sweeeet!!!
Old 05-07-2006, 12:03 AM
Brent,
Glad to see that the block made it ok and that you are happy with it. It took me a litle longer than I thought but still pretty quick. Hope you find all of the machine work to be to your liking.
If anyone is having any problems with delivery time or getting your parts, feel free to call me and we will be happy to help any way that we can. We keep a lot of Ford parts in stock. Thanks, Keith Craft
Keith C
Old 05-11-2006, 08:35 AM
Cobra Make, Engine: Dreaming of a 427 Competition car...
That is truly a thing of beauty!
Paul
