Old 06-28-2006, 06:41 PM
Rwillia4's Avatar
Default Jon Bennett Engines
Does anyone have any opinions about Jon Barrett 427's?? They seem low priced...
http://www.jonbarrett.com/
Old 06-28-2006, 08:11 PM
Its a small block.
Kinda like a Briggs & Stratton.....
Old 06-28-2006, 09:23 PM
Cobra Make, Engine: BDR 302 AFR 165
Looks like a lot of bang for the buck. I have never had any experience with this builder but I'm sure someone here has. I like the 408 stroker but to each his own.
later
dennis
Old 06-29-2006, 04:05 AM
WV66AC's Avatar
Cobra Make, Engine: Late 70s Allied Industries?? 454 BBC; alum copo heads and intake THM 400 12 bolt posi ++ 06 CL 55 AMG
There is a show on Speed regarding Barry's Speedshop -- "Wrecks to riches" or something like that. He installed Barrett engines in his makeovers. Seemed to sell at auction OK.
Old 06-29-2006, 05:36 AM
ffindling's Avatar
Cobra Make, Engine: Findling 001 - starting scratch build
Smile Barry White....
Barry White used Jon Barrett engines in most of the TLC "Wrecks to Riches"
buildups with the exception of the '69 Hemi Dart build and the '70 GTO build.
White had purchased an old Keith Black hemi block for the Dart but the block
turned out to be cracked and unrepairable, so he had to settle for a Mopar
crate hemi for the Dart. The GTO used a Butler Performance 461" Pontiac
setup. Barrett doesn't build Mopars or Pontiacs, but Barry White seems to
use Barrett's engines if he can supply the type appropirate for the build.
....Fred
Old 06-29-2006, 08:14 AM
Poolw's Avatar
Cobra Make, Engine: SPF, KC 427
I think he's using a 4.170 stroke and a 6.250 rod which is not a good ratio with a 4.040 bore. Roush and Keith Craft use a SB Dart Block with thicker cylinder walls and they do a 4.125 bore and a 4.0 stroke with a 6.250 rod producing a much much better stroke to rod angle. The problem is with a low stroke to rod ratio is piston scuff and wear. Thus shorter pistion/engine life. Spend it now or spend it later.
Poolw
Old 06-30-2006, 12:25 PM
Rwillia4's Avatar
Poolw,
Thanks, I'm not very smart in the over-square, under-square aspects of engine building. For a SVO Sportsman II block is this a standad bore? And with this I can expect more torque and an engine that doesn't spool up as fast, right?
rwillia4
