Old 08-05-2006, 11:27 AM
Red face Valve guides
How do I test to see if my valve guides are bad?
Guy
Old 08-05-2006, 11:50 AM
Cobra Make, Engine: Butler Racing/427 side oiler
shouldnt have any play at all, I just did mine ...brass so they should fit tight ...the brass wears
Old 08-05-2006, 12:12 PM
The technical way is to actually measure the valve stem and the inside of the guide. Of course few of us have the tools to do this. The clearance required is very small indeed, but the valve should move freely up and down in the guide and not 'wobble' around. Remove the valve springs to get a 'feel' for it. If in doubt, your off to the machine shop to have it verified.
Old 08-05-2006, 12:23 PM
I need to check the valve guide for leaks.
Guy
Old 08-05-2006, 12:25 PM
Leaks are usually caused by the valve stem seal that sits atop the guide. I don't know how you would check the 'leakage' of a valve guide, interesting question!
Old 08-05-2006, 03:25 PM
Woodz428's Avatar
Although I have never done it, I would imagine that you could pressure test like on a leakdown, but with the valves open. You would need to block off the carb flange and the exhaust with the valve covers off, but you could detect any leakage. I'm not sure it would be of any value since you wouldn't have a clue as to HOW much it was compared to a good one.
WDZ
Old 08-05-2006, 07:51 PM
undy's Avatar
Pick a cylinder and bring the piston up to top dead center. Pressurize the cylinder with LP air. Make sure you don't drive the piston back down in the bore, "locking" the crank if necessary. Using an "on the engine" spring compressor, pull the retainer/locks on both valves. Pull the springs, intake and exhaust. Let the air pressure of the cylinder. Note: with the piston up on TDC the valves can't drop much. Grip the ends on both valves and move them up and down in the guides while wiggling them right and left, front and back. If there's slop in the guides you'll feel it. If you can "feel" it then it's excessive. With a dial indicator you can get exact readings.. The whole process just takes several minutes.
Dave
Too many toys?? never!
Old 08-05-2006, 10:42 PM
Yeah, like Undy said.
Old 08-06-2006, 11:00 AM
Heres one way to remove the valve springs with air pressure in the cylinder.
Old 08-06-2006, 06:30 PM
GREAT, JUST GREAT! How'd you get that picture??? That's all I need, paparazzi taking pictures in my garage of my 'secrets'...
