Old 09-08-2006, 06:32 AM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Engine Identfication Help
I am looking at a FE block and a little uncertain on the identification of it.
The date code indicates it is a Jan, 1965 block.
The casting number is C5AE-A
Going to fordifiction.com and their chart of casting numbers, it appears the block could be one of three:
390 or 330HD or 427 top oiler
The block has a flex-plate still bolted to the crank which indicates an automatic transmission. With that in mind, I would rule out the 330 since that was a HD truck motor - unlikely it was an automatic
Is there a way to tell if it is a 390 or 427 without pulling a head or pan or trying to second guess the stroke thru a sparkplug hole?
Are there other numbers that I should be looking for?
Paul
Old 09-08-2006, 06:38 AM
flwolfman's Avatar
Cobra Make, Engine: None at moment
It is almost impossible to indentify an FE due to it's lack of numbers without getting the number off of the crank and measuring the bore. It is probably a 390. Does it have cross bolted mains or any other giveaways like screwed in freeze plugs? Jim
Old 09-08-2006, 06:40 AM
PaulProe's Avatar
Jim,
looking at digital pictures so I can't really tell.
It would be a top oiler and I think they had regular freeze plugs
Did they have the bosses for crossbolt mains? or was that only the side oilers?
Paul
Old 09-08-2006, 06:47 AM
flwolfman's Avatar
A lot of the 427 top oilers have the cross bolted mains, but not all of them. Freeze plugs could be either. Someone else will jump in here with a miracle solution. I would pull the pan. Jim
Old 09-08-2006, 01:01 PM
Im curious where do you actually look to find these numbers?
Thank you
Old 09-08-2006, 01:32 PM
flwolfman's Avatar
I would look on the crank to see what type of crank is in the engine. Could have a 390 crank or a 428 crank or a 352 crank. The number is on one of the balancers.
