Old 10-02-2006, 05:39 PM
Cobra Make, Engine: Butler Racing/427 side oiler
Default This would look good in my car:)
http://cgi.ebay.com/ebaymotors/FORD-...34051946QQrdZ1
Old 10-02-2006, 05:54 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Will it fit under the stock 427 Cobra hood scoop?
55 mph is unsafe at any speed. Huh?
Old 10-02-2006, 07:04 PM
That I would highly doubt ...but hey ..whats a hood worth?
LOL
Old 10-02-2006, 10:20 PM
There are a few motors out there I just don't have a problem with seeing under the hood of a replica. THIS is surely one of them!
Old 10-02-2006, 11:17 PM
I'd buy it, but it's got those darned aluminum rods...
Old 10-03-2006, 04:21 AM
Tommy's Avatar
I'm not very well informed about Cammer engines, but I thought they had a large chain assembly on the front to drive the overhead cams. This engine doesn't appear to have one. What am I missing?
Tommy
Previously owned EM Cobra
Old 10-03-2006, 04:34 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
A well done example of raw HP!!!
Yes, it would look okay under your hood, but it would look even better under mine.
Old 10-03-2006, 05:01 AM
Tommy, the front cover covers the chains. I think there was a manufacturer who also made a gear drive setup that eliminated the chain.
Old 10-03-2006, 05:51 AM
Ron61's Avatar
Post
I believe that Blykins is right. I have seen two with gear drives and they said the chains had a tendency to stretch just enough to throw off the timing after having been ran hard for a few times. I dont know if this is true or not and was just an excuse for them to have gear drives made.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 10-03-2006, 08:06 AM
trularin's Avatar
Member of the north
GUYS!! It does not appear to be a real CAMMER.
Read the song and dance.
Old 10-03-2006, 08:14 AM
Well it appears to have the SOHC heads and they're definitely tunnel port pieces. The valve covers wouldn't fit on any other FE head.
I think what's throwing you off is that it says it's not a cammer block. I would take that to mean it wasn't an original NOS cammer block....but is probably a regular 427 block that has been drilled for the cammer heads.
Old 10-03-2006, 08:25 AM
elgecko's Avatar
A Continuation Cammer
Old 10-03-2006, 09:11 AM
Say it aint so elgecko!
Certainly as good a replica as I've even seen!
So how are the valves actuated when these heads are used on a standard 427 block? Pushrods?
Old 10-03-2006, 09:26 AM
fastraxsg's Avatar
Evryday is a roadstr day
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
Over 10 grand is a lot of money for a maybe/maybe not cammer....would imagine there has been a flurry of emails between bidders and seller before they bid like that....seems for that amount, you wouldn't be buying on ebay, sticking to a reliable/known builder
Old 10-03-2006, 09:33 AM
Considering cammer's typically sell for better than $30 grand and it's not uncommon for a nicely built side oiler to sell for better than $10 grand, maybe the reserve price is 'reasonable' for a 'replica' cammer built on a side oiler block.
Old 10-03-2006, 10:11 AM
undy's Avatar
The "original" cammer block had oil drain-back holes in the rear. The differences didn't have anything to do with the valve train. Pond and Genesis blocks alread have the drain-back holes.. Other 427s can be modified, as this one evidently has.
Too many toys?? never!
Old 10-03-2006, 10:31 AM
Ernie, I would imagine since the cam is not in the center of the block on a cammer, that pushrods would not be needed.
I can't remember off-hand, but I think the SOHC heads have rocker shafts and rocker arms like a regular FE. The shafts run parallel to the cam. I would like to know the answer to this myself....I know regular SOHC engines allow the cam lobe to push a follower which opens/closes the valve. However, since the cammer FE has rocker shafts, I can't really say how they work.....maybe the cam lobe itself lifts the rocker arm.
Old 10-03-2006, 10:41 AM
A SOHC with modern gear set.
Old 10-03-2006, 10:45 AM
SOHC with chain (chain is something like 6 feet long?).
Old 10-03-2006, 10:47 AM
Default cammer
the motor is a cammer,it has correct timing cover,block is same as standard block with exception of drainbacks in back of deck surface,rockers run on overhead cams directly,distributor is being driver off idler behind timing cover,not mine but ive owned 6 of these
