December 2025
| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
11-14-2006, 05:06 PM
Fired it off today!!
Damn, she sure sounds nasty..
The Pond 482" S/O made her debut this afternoon. She was accompanied by a host of other "go fast" goodies.. Flywheel horse power should be around 650+hp 650tq. The chassis dyno will tell the real deal though.
I did several heat cycled runs and there are no drips of any kind. Oil remains clear and untainted. Everything points towards a successful initial break-in. I'll go back and readjust the valves later this week or this coming weekend. After the valve adjust it's off to the tuner for some chassis tune 'n dyno time.
Dave
Too many toys?? never!
Advertising
11-14-2006, 05:28 PM
Cobra Make, Engine: BDR 302 AFR 165
Congrats on the start up. Roller or Hyd cam?
later
dennis
11-14-2006, 05:53 PM
later
dennis
yes and yes.. hydraulic roller. It's a custom grind Keith Kraft has Comp Cams do for him, 246/248@0.050" & .640ish lift
11-14-2006, 06:09 PM
Mi
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
You're gonna like that motor,...
What kind of gear box, and rear gear, are you running?
11-14-2006, 06:18 PM
I already do...
TKO-600 w/ .64OD. Ram "Long Style" 2800lb pressure plate, Ram SFI aluminum flywheel w/sintered iron clutch disk, 26 spline. Lakewood bellhousing/block plate.
11-14-2006, 06:23 PM
Mi
What about the rear end gear ratio? Just curious because I think I know what you're in for!
11-14-2006, 06:28 PM
It's 3.73 to 1 ...
11-14-2006, 06:40 PM
11-14-2006, 06:47 PM
Mi
Have fun with it!!
11-14-2006, 08:39 PM
Tx
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
That motor will be bas add. Not to be nagative, but I hope your not too short on the rears and too tall with OD. Either way your really going to enjoy 2nd, 3rd and 4th!!!
Bruce
11-15-2006, 08:37 AM
Mi
Bruce
That was the reason for my interest. I have nearly the same set up with the exception of the aluminum flywheel, and my rear gear is 3.50:1 I have a hole between 60 and 70 mph where the cam is not happy. It's not bad, but it's there. In Michigan, most highways are 70mph and 10 over is usually overlooked, so on the highway I will be fine, but the 55 mph two laners out in the country will be a fourth gear drive. I think his 3.73 will be perfect for the fifth gear OD.
Brad
11-15-2006, 09:44 AM
ca
Cobra Make, Engine: owned Kirkham for 11 years
Congratulations, Brad
I have the same trans. od in my Kirkham and a 3.42 rear, works great and I think with your slightly lower rear end, yours will be great.
Maurice
11-15-2006, 10:03 AM
MD
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Very Nice.
Wish the video was longer.
Might see you out there. Brother lives in Colonial Beach.
I know it's not Va. Beach but you never know.
11-15-2006, 07:25 PM
CT
Cobra Make, Engine: HM-2027 / 427 SO
Sweet!!!
G.
