Old 01-04-2007, 07:40 AM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Default 427 NASCAR side oiler?
I've heard of some 427 side oilers referred to as having "NASCAR" blocks. Are all side oilers the same, or is there a difference between them? If they are different, what are the differences between the two?
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 01-04-2007, 10:49 AM
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default NASCAR blocks
I have several books on the 427 center and sideoilers. Nothing is written to indicate that a NASCAR block is any different than the factory FOMOCO 427 blocks. Probably the only differences might take place during the engine builds by the race team, as Holman-Moody did in the 60's. There might have been a few minor tweaks to improve oiling but I have not read of them anywhere. I think most of the teams of that era actually used the same LeMans rods produced by Ford because the entire rotating assembly was made from forged materials and were the best available at the time.
Many very knowledgable people will tell you that the 427 sideoiler is probably the best true high performance engine that was ever mass produced for production cars. Of course the SOHC that followed in late 64 and 65 was probably THE best, but they were outlawed by NASCAR and were limited to drag race teams. But these engines were hand assembled and never "mass" produced.
Old 01-04-2007, 10:58 AM
Even the SOHC blocks were standard 'side oiler' blocks. NASCAR outlawed the High Riser heads for the same reason they did the SOHC, to much for the competition! Rare High Riser heads went away in '64 and were replaced with the more common medium risers.
However the side oiler NASCAR CRANKSHAFT was heavily modified and required special rod bearings (and rods I think). The NASCAR side oiler rod bearings are really hard to find, by the way.
Old 01-04-2007, 12:14 PM
CSX 4027's Avatar
Default Nascar
LeMans rods due to their narrow .919 pin didn't last. Bearing to narrow
They weighed 850 grams without good bolts.
NASCAR Rods were in fact wider but came in at about 1000 grams ugh..
You could do your morning curls with them.
The crank was no great shakes either.
In todays world and since no-one can see thru your block at a car show, the best 427 FORD builders use custom gun drilled billet cranks cut to accept,,,,
are you ready....
Chevy big block rods with the .990 pin
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 01-04-2007, 12:32 PM
Rick Parker's Avatar
The "Nascar" blocks were hand picked after selecting the ones with the least core shift, thickest cylinder walls etc and fewest potential casting flaws.
Old 01-04-2007, 01:33 PM
Archrms's Avatar
Rick & Steve,
If I understand you both correctly, there is no difference between a regular and a NASCAR block, except that the NASCAR blocks had heavy duty parts inside. So there should be no way of telling them apart from the outside. They would have to be torn down to see what is inside of them. Is this correct?
Old 01-04-2007, 01:47 PM
CSX 4027's Avatar
Default Nascar
Originally Posted by Archrms
Rick & Steve,
Yes, and you don't want those internals. They were designed to run at a constant high rpm for 500 miles.
Steve Sunshine
"Hurry Up And Live"
Old 01-04-2007, 03:44 PM
I beg to differ...
Old 01-04-2007, 04:44 PM
Well I hear you J. Martin!
But really, I wouldn't want those internals myself, to complicated finding the right parts if you had to rebuild.
NASCAR blocks 'hand picked'. Of course, so were the valves, each rod, each bearing, each keeper and every other component. Pull up a chair and go through BOXES of parts finding the perfect specimen. It's STILL done that way, right down to the tires.
Old 01-04-2007, 05:06 PM
It's not as bad as this site deplicts , the block uses all the fe bolt on parts .If some how the crank need work, chevy rods can be sized ...
Mine is new old stock w/ edlbrock heads ss valves pro built . Most cobra engines (F.E.SO)don't see much what they were built for.
Old 01-04-2007, 05:54 PM
CSX 4027's Avatar
Default Don't beg
[quote= Most cobra engines (F.E.SO)don't see much what they were built for.[/QUOTE]
I beg to differ too.
My old 427 did see over 2000 track miles chipped at 7000 and run up there all the time with a toploader and 3.73 gears
It was standard bore/standard stroke/chevy crank/rods
The car with it's new owner is still honkin with over 6000 miles.
The car spent a few years at Shelby LV and was used as a demo-ride car by Gary Patterson who claimed it was the sweetest one he ever drove.
Steve Sunshine
"Hurry Up And Live"
Old 01-04-2007, 06:18 PM
I would agree with john. Most cobra 427 SO's, as well as most cobra's, don't see alot of track time. More street time.
My old 427 --- spent a few years at Shelby LV and was used as a demo-ride car by Gary Patterson who claimed it was the sweetest one he ever drove.
Yeah, he probably says that about every cobra he drives. Was it late in the evening, lights low, and was he drunk ?
Old 01-04-2007, 07:07 PM
John Martin......I like your avitar.
