Old 01-09-2007, 09:39 AM
Tom of VA's Avatar
Cobra Make, Engine: Superformance #095, w/ 1966 428
Default plug recommendation
Anyone have a spark plug type & gap recommendation for by newly built 428 with 10.5:1 and a MSD dist & 6AL ignition?
Old 01-09-2007, 12:01 PM
Your engine is very similar to my engine. I use Champion 426 (RC9YC5) gapped to .040 -- others will no doubt have different recommendations.
Old 01-13-2007, 11:08 AM
New Car Craft (March) pg 36 has an article about finding the best choice for plug design and temp range. I have yet to apply it myself. It's about five pages long.
Mike H
Old 01-13-2007, 12:16 PM
Naumoff's Avatar
Are you running Alloy or Cast Iron heads?
Cast Iron for Street/strip
Motorcraft BF-32
Autolite 35 or 34
Champion F-11YC or F-9YC
Accel 378
Aluminum Edelbrock
Motorcraft AGSP-33C
Autolite 3926
Champion RC-12YC
Accel 416
Gap Electronic 44
Point type 35
Hope this helps. This is for street and strip if you go full comp use a colder plug and a smaller gap.
Old 01-13-2007, 01:09 PM
BOURRET's Avatar
Cobra Make, Engine: Paint:Metalflakes Royal and Abalone stripes registered in France in 1973. Engine: Ford Shelby aluminium block, 482; two 4-barrels 600cfm Holley; Edelbrock Performer Aluminium heads,,fluid damper,4-speeds Aluminium Toploader (short), 2.88rear
Send a message via Skype™ to BOURRET
Motorcraft BF-32
Autolite 35 or 34
Accel 378
Aluminum Edelbrock
Motorcraft AGSP-33C
Autolite 3926
Champion RC-12YC
Accel 416
Gap Electronic 44
Point type 35
Mine: Alu Edelbrock heads
Plugs: Champion RC12YC
Engine: 482 FE alu Shelby block
Gap. .7mm
Queenie
Old 01-13-2007, 02:49 PM
lineslinger's Avatar
Naumoff
Why does the alloy of the head dictate a different plug, is it the heat retention of the alloy with which the head is made?
Does the multiple spark given by the MSD during the firing stroke have an influence as well?
Old 01-13-2007, 10:16 PM
RedCSX1's Avatar
The Edelbrock heads take a smaller diameter plug. I run Autolite 3926 which is the most recommended plug for FE motors. Dyno test have shown that you gain nothing from a larger than 35 point gap. I have a 6AL box with MSD coil and distributor.
Morgan LeBlanc
Fresno CA
Old 01-14-2007, 08:41 AM
Naumoff's Avatar
Originally Posted by lineslinger
Naumoff
As Morgan said the Edelbrock Alloy heads have a smaller plug tap diameter.
Morgan, You are right about no HP gain for gap. With our engines running 10:1 compression or higher a smaller gap is fine. A larger Gap would be needed for a low compression engine.
The multispark is to make sure that the fuel in the cylinder fires. It is a better chance NOT to have a misfire in each cylinder.
