February 2026
01-16-2007, 04:38 AM
Originally Posted by Anthony
No, I was wondering if you had a set of Dove tunnel port heads , with the raised exhaust ports, for better exhaust flow, i.e. more HP.
Oh my bad!!! Sorry. I forgot about the TP Dove's. I have heard good things about them flow wise tho. I have flow numbers for those somewhere. I'll find them and post them for you.
G.
01-16-2007, 06:02 AM
OH
Originally Posted by double ugly
Will the turkey pan fit under the hood. I plan on running a Holley 750 with a turkey pan.
Thanks, John
Yes, it should.
The air cleaner is the problem, and I had to make my own.
01-16-2007, 06:59 AM
az
On the Hi Tech I had a stellings air cleaner on a Holley 750 and, as I recall, it was just above the turkey pan. The turkey pan was an inch or more below the hood. I better go with a medium riser or tunnel port head. Thanks alot for all the information.
double ugly
01-16-2007, 09:55 PM
OH
With Hi-Riser heads, and with the factory single 4bbl, dual plane intake, the carb/turkey pan sits 0.5" higher than with the sidewinder or Blue Thunder intake with MR heads. I have Hi-Risers on my engine, turkey pan as well.
01-16-2007, 11:21 PM
High Risers aren't for everybody, only 'special' people (like me)!
01-27-2007, 05:55 AM
az
Anthony, do you use the stelling (sp) air cleaner? If so did you have to modify it? Thanks.
double ugly
01-27-2007, 06:01 AM
OH
No, I didn't even try to use it, as it is so restrictive, it was defeating the purpose of the engine.
I made my own air cleaner, with air cleaner foam. I'm sure it flows much better than the stellings, or even K&N 9", which I tried to use first, and it wouldn't fit.
01-27-2007, 06:19 AM
az
Did the stellings fit under the hood or didn't you try? Thanks, John
double ugly
01-27-2007, 06:23 AM
OH
didn't try it.
01-27-2007, 07:27 AM
az
Does the turkey pan seal to the hood? If not, do you know how much clearance there is? Thanks.
double ugly
01-27-2007, 11:57 AM
OH
It doesn't seal to the hood, but it is awful close, probably 1/2 - 1".
01-27-2007, 01:22 PM
az
So if I put a rubber seal on the pan it should seal. Thanks alot.
double ugly
01-27-2007, 03:02 PM
OH
Maybe/probably. To really measure the clearence from the top of the turkey pan to the underside of hood, what I have done was to tape a telescoping radio antenna to the side of the turkey pan, so the tip extends up. Close the hood, and then you can see what the clearence is between the top of the pan and underside of the hood. take the measurement at all 4 corners of the pan. Then you can tell how thick the rubber seal/foam needs to be to touch the underside of the hood.
01-27-2007, 06:33 PM
Of course engine torque\vibration should be accounted for if it comes in contact with the hood.
