Old 01-23-2007, 09:07 PM
Mike Bartlett's Avatar
Cobra Make, Engine: CSX4771-CF. 1966 427 S/O
Default Best method for seating the rings
Just wanted to get some tips on the best way to be sure the rings will seat properly. I plan on honing my cylinders with #220 grit honing tool, V shape style with 3 honing rods. I have brand new plasma-moly rings. Cylinders are straight and true. 427 S/O .015 over bore. 66 cast iron block. 11.3 Static Compression.
-Is Rotella a good break-in oil? Other suggestions.
-When I first start the motor do I let it run at say 2000 rpm's for a certain amount of time?
-First time back on the road I assume I should vary my speed. Should I push the motor hard or take it easy.
-Any other tips/tricks?
Thanks,
Mike
Rubber peelin' gears a jammin'!
