Old 04-07-2007, 06:36 PM
82ACAUTOCRAFT's Avatar
Cobra Make, Engine: AC Frua, FE Side Oiler
Post Iron Genesis Block
How good is the Iron Genesis block? Compared to an original 427 or compared to the various aluminum blocks on the market? your input appreciated. I want to build a good street motor around 500HP, smooth and reliable for long distance driving to shows etc. stroker crank, hydraulic lifters and vacuum secondary carb. Something very tractable matched to a toploader. Thanks
Old 04-07-2007, 06:59 PM
jwoodard's Avatar
Thumbs up
I have a Genesis cast block and it is terrific. If you use a good, reputable builder that does good machine work you won't be disappointed. From what I've been told, the new blocks are stronger with more material in the right places allowing for larger bores without any heating issues. Mine is 496 c.i.'s, runs strong and cool.
You will be able to exceed your desires with no problem.
Jim Woodard
Old 04-08-2007, 05:38 AM
I've run Genesis iron blocks at 750+ horsepower...
Old 04-08-2007, 06:38 AM
Cobra Make, Engine: kirkham 427 stroker
Default genesis
keith craft way to go at 612hp i am still scared to stomp on the pedal
Old 04-08-2007, 08:12 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
is genesis making the aluminum blocks?, i cant seem to find any one that has them?.
Old 04-08-2007, 08:19 AM
I did not mean to select the thumbs down, it was by accident! I tried to change it but it did not go away everywhere!
Old 04-08-2007, 09:01 AM
This is a perfect place to use the ol' Club Cobra search tool. I can't remember any negative comments once the teething problems were solved and I've heard post after post about how good they are. I have only about 2,500 miles on a 496 stroker (3.310 bore X 3.250 stroke). Dynoed at 607 HP with 9.4:1 compression. I might even run 87 octane in it to see if it pings. Runs cool, doesn't leak. What else could you want?
Good luck,
Brian
Old 04-09-2007, 10:13 AM
Don McCain's Avatar
Cobra Make, Engine: Shelby CSX4870, Shelby 496
Red face FE Bore x Stroke
Don't you mean 4.130 X 4.250 ?
Old 04-09-2007, 10:15 AM
Don McCain's Avatar
4.310 X 4.250 We all make typo's don't we!
Old 04-09-2007, 10:36 AM
Bore = 4.310
Stoke = 4.250
What's an inch or two among friends.
Old 04-09-2007, 10:38 AM
Don McCain's Avatar
Depends on who the friends are if you know what i mean. Have a good one.
Old 04-09-2007, 10:42 AM
computerworks's Avatar
Fixed the thread icon for you.
ron
ClubCobra Moderator
Old 04-09-2007, 12:06 PM
jwoodard's Avatar
Thumbs up
And I edited my post!
Jim Woodard
