Old 04-27-2007, 02:44 PM
Cobra Make, Engine: ERA #678 427SO/468 Cu in.
Default Dyno Question
I had my BB dyon'd the other day and when I rec. the report, I noticed that the curves did not cross at 5200 RPM. I like the numbers but I wonder if it is accurate. 427 SO. w/' 750 Mech. Holley. Max Torque: 434. Max HP 373 at rear wheels. AF Ratio 12.7. What do think?
Mike R
Old 04-27-2007, 03:13 PM
I don't think there are any exceptions at all. Both curves should always cross at 5252.
Old 04-27-2007, 03:31 PM
The curves won't appear to cross at 5252 if the scales for the HP and torque are different.
Old 04-27-2007, 03:32 PM
Good point Anthony. I'm used to seeing both curves on one graph....but they may have separated his.
Old 04-27-2007, 03:35 PM
Default Dyno
Your are correcto mundo! The scales are different. What do you think of those #'s for my BB though?
Old 04-27-2007, 03:40 PM
Seems pretty stout.....very torquey. Probably about 500hp, 550 lb-ft if I were to guess.
Old 04-28-2007, 04:57 AM
Default Nice numbers Mike
mrud Mike Nice numbers, should run strong through the midrange. Your numbers are almost the same as mine. I have a 452 motor. 12.5 in the 1/4 mile, about 108mph. 12-14 gpm. stress relief YES. Face hurts after road test from smile PRICELESS. Don't worry if the lines on the graph don't cross at 5K. It starts, runs, turns right, turns left, and most important it STOPS!! That's at you need. A nice sunny would be nice too. Rick L
Old 04-28-2007, 06:04 AM
Actually, the curves can be on the same graph, but with different scales. For example:
