Old 09-24-2007, 04:23 PM
Cobra Make, Engine: KMP 498
Question Pressure Testing The Engine
After my engine is all assembled waiting to be installed into my chariot of fire, What about pressure testing the engines's water system?
I could block off the waterpump block holes easy enough then block off the intake thermostat area, right? Then put some water in it and pressure it up, seeems easy enough?
Anybody do this? What pressure would I test it to?
Old 09-24-2007, 04:47 PM
wtm442's Avatar
Beam Me Up Scottie
Pressure it to a few psi higher than the radiator cap pressure rating. But you want to do this after all the water pump, plumbing, hoses etc are installed.
Warren
Old 09-24-2007, 05:02 PM
I agree. But you might want to break your engine in before you put it in your car. If you haven't already, that is....
Old 09-24-2007, 05:16 PM
How much pressure do they use to check a block or heads?
Old 09-24-2007, 06:33 PM
Cooling system pressure tests usually run from a low of about 17 lbs. to a max of the upper 20's, depending on the cooling system.
