Old 11-03-2007, 04:14 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default erson rocker assbly and head studs?
does any one know if the erson rocker assbly for the fe clear the arp head studs?, i thought i read some where that they had a problem ?. but it was from a few tears back.
Old 11-03-2007, 04:48 PM
I've had them hit. I shorten the studs in a lathe...and shorten the 6 point nuts a bit too
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 11-03-2007, 05:49 PM
Default Yes they hit in a shelby motor
wrench 87 Yes they hit in a shelby motor with studs. I machined the supports to clear the nuts and trimmed .150" off the stubs to clear. Other than this the system works good. I run an .080 oriface in each oil supply port to the heads. no problem of blueing at this time. A couple of guys have gone to using hydro roller lifters with the oiling coming through the pushrods to help keep the end of the pushrod and adjuster end from blueing. I think this happens with strong valve springs and high lift cam shaft. I am running the 587-607 cam. I also have beehive springs on the heads and not the shelby ones that came with the heads. Less wieght on the valve train means better control. Less bouncing off the valve seat. More HP and rpm to work with before valve float or hydro lifter pump up. I max the rpm limit to 6,200 after breakin of this motor. A 482 motor is large for this cam, but a 427-452 motor will make this a nice torker motor. Rick L.
Old 11-03-2007, 05:56 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Hit on Edelbrocks also
The studs will hit the bottom of the stands on Edelbrock heads also.
I spoke to Erson and they said to grind clearances into the bottom of the stands. I cut some elliptical reliefs, about .200 deep on them.
If you go this way, put the studs in then put the stands on and whack them with a mallet to mark the bottom of the stand. You'll find each stud is in a different location on the stands.
They cut pretty easy with a die grinder and carbide bit. Clean them real good before you use them. You'll have aluminum chips everywhere.
Paul
www.65shlb.com
www.prdcrrct.com
Old 11-03-2007, 07:56 PM
i was also looking at the harland sharp set up will these have the same clearance problems?
