Old 01-20-2008, 10:30 AM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Default Question about Quicktime bellhousing, stamped steel valve covers
Where is the best place to get:
Chrome stamped steel valve covers (see pic)?
Original style pulleys?
Anyone use a Quick Time bellhousing on a Pond alum block yet? I spoke with Steve at Fortes. He said the QT bellhousing was not working on the Pond or Shelby Alum blocks and that QT might manufacture a new bellhousing to address this problem.
Old 01-20-2008, 10:48 AM
xracerbob's Avatar
I'll let you know next week when my motor arrives. I already have the QT bellhousing. What were the issues regarding the Pond block?
Old 01-20-2008, 02:37 PM
I`m also curious as to why the Quicktime unit won`t work on the Ponds or Shelby block as I have a Ponds 482 on the engine stand waiting for the Quicktime bellhousing I just ordered ????
Thanks .
Old 01-20-2008, 05:36 PM
Don't know why it won't work. Call Quicktime to confirm or disprove what Steve at Fortes told me.
Old 01-20-2008, 10:26 PM
alpace@pacificp's Avatar
Cobra Make, Engine: Kirkham #492/ 427/482 Keith Craft. Simple, Clean.
Default Quicktime
Hmmm. I have A Keith Craft Pond 427/482 with Quicktime Housing and it seems to be fine.
Might Call Joe Weight at Kirkham to ask for details?
VNMS 65
Old 01-21-2008, 05:20 AM
undy's Avatar
Don't know why Quicktime "possibly" has problems but my Lakewood bolted up to my Pond block perfectly w/o offset dowels or any other welded alignment modifications. I "dialed in" the bellhousing too. It had < 0.002" misallignment, well within the allowable deviation of 0.007".
Too many toys?? never!
Old 01-21-2008, 07:17 PM
CC Member / Sponsor
Originally Posted by hi-tech cobra View Post
Anyone use a Quick Time bellhousing on a Pond alum block yet? ... He said the QT bellhousing was not working on the Pond or Shelby Alum blocks ...
I don't understand. We have used them on both blocks.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 01-21-2008, 07:27 PM
Cashburn's Avatar
Backdraft Racing Dealer
There were a couple different versions of the FE / TKO bellhousings that came out early on. I believe the current housings should work with all blocks.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 01-21-2008, 07:29 PM
CC Member / Sponsor
The bell housing we used were for the Ford style transmission. This is the shorter of the two bell housings.
Cubic Performance
HiTech Legends
Evolve Lubricants
Old 01-22-2008, 05:09 AM
Default Barry, does it work?
It would be interesting to see what Barry R.'s experience has been. Steve said he just shipped him one.
Barry you out there? Does it work?
Old 01-22-2008, 07:11 AM
I sent an e mail to Ross McCombs at QuickTime asking him about this and his answer is " I am not aware of any reason it should be different from a OEM 427 block" referring to the QuickTime bellhousing .
Also talked to Steve at Forte`s and he is waiting feedback from some customers who are installing QuickTime bellhousings on Ponds blocks .
Old 01-23-2008, 05:48 AM
I have the bell and the block sitting here. Simply have not had time to attach them together yet. From what I was told the issue may lie in the combined use of a Powermaster starter with the solenoid. I have one of those here too.
I'll try to click them all together and see what happens....might be a day or two.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 01-23-2008, 06:19 AM
Thanks Barry. Looking for your update.
Old 01-28-2008, 05:54 PM
Got it mocked up....
Pond block, Quicktime bell, Powermaster starter...
They do not fit At least not as a simple bolt together.
It appears that the problem is with the Powermaster and the Pond block. I do not think the bellhousing is at fault.
The Powermaster has the battery power stud pointed toward the block - opposite of a normal Ford part. The Pond block has extra cooling and thus is wider in the water jacket area. The stud ends up .018 from the block - - just too close to be safe. I think we can clearance the block and shorten the stud to make it work. I still would want to fully insulate the connection - maybe with a shortened spark plug boot.
Old 01-28-2008, 09:12 PM
Barry,
Thanks for the update. What about a different starter?
Old 01-29-2008, 11:10 AM
SSSammy's Avatar
Default Pond + Tilton = :)
Don't know if the Powermaster you have can be reclocked, but you can turn the Tilton solenoid and Batt terminal to three different orientations. I had the same interference problem when I tried to put the Tilton on right out of the box.
Sam
P.S. .. I should mention that I did have to machine the face of the Tilton mounting plate to get the pinion gap in spec. See the earlier thread.
Old 02-14-2008, 05:14 AM
Default Barry did it work?
Hey Barry,
Any progress on the Pond block / Quicktime bell-housing issue?
Old 02-14-2008, 06:04 AM
Yep,
Powermaster has a different part number that puts the battery terminal at the end of the solenoid - I need to get the number off the box. No problem with that one!
Old 02-14-2008, 06:27 AM
Barry,
Thanks for the update, post that part # when you get a chance.
Old 02-14-2008, 05:59 PM
xracerbob's Avatar
I have the Pond Block, QT bellhousing and this starter:
RobbMc Performance Products - Ford A/T Starter
This starter seems to fit fine and is light and compact. A little pricey maybe, but a great product. I got their fuel pump too. Also a nice piece.
