Old 04-23-2008, 07:41 AM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Default Torque Specs
Does anyone have a link for FE torque specs?
Old 04-23-2008, 07:58 AM
franklin's Avatar
Cobra Make, Engine: Polished KMP #488 / 427SC, 427 SO/482 by KC
A link to torque specs for hardware would also be a nice reference if anyone knows of one?
Old 04-23-2008, 08:07 AM
It depends on the fastener...which ones are you needing?
Old 04-23-2008, 11:56 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Go to the ARP site.
http://www.arp-bolts.com/Catalog/Catalog.html
Old 04-23-2008, 12:50 PM
danc30's Avatar
Here is a start for you if you have Edelbrock aluminum heads.
http://www.edelbrock.com/automotive_.../6000/6005.pdf
Old 04-23-2008, 12:51 PM
Cobra Make, Engine: LA Exotic
Try Boxwrench.com
Old 04-23-2008, 04:56 PM
danc30,
Sent you a PM.
JB
Old 04-23-2008, 06:41 PM
Clois Harlan's Avatar
Notice the torque is measured in INCH POUNDS up to the 5/16" bolts (to arrive at foot pounds divide the torque by 12) and I think these are for grade 5 bolts. Even if you are bolting down aluminium heads you still need about 105 ft lbs of torque but you MUST use the special washers (I just bought some for about $65.00) that go with the ARP Bolts.
Bolt Torque Specifications
BOLT SIZE TORQUE
1/4-20 85 in-lb
1/4-28 103 in-lb
5/16-18 180 in-lb
5/16-24 198 in-lb
3/8-16 22 ft-lb
3/8-24 30 ft-lb
7/16-14 42 ft-lb
7/16-20 47 ft-lb
1/2-13 65 ft-lb
1/2-20 77 ft-lb
9/16-12 95 ft-lb
9/16-18 105 ft-lb
5/8-11 110 ft-lb
5/8-18 120 ft-lb
"Let's roll"
"Be part of Something Good
Old 04-24-2008, 03:37 AM
undy's Avatar
I think Steve Christ's "How To Rebuild BIG-BLOCK FORD ENGINES" provides the single best reference for FEs, to include torque specs. It comes highly recommended by the FordFE.com guys. I have it opened up on the bench everytime I crack a valve cover, well...almost every time.
http://cgi.ebay.com/How-to-Rebuild-B...2em118Q2el1247
http://www.amazon.com/How-Rebuild-BI.../dp/0895860708
Dave
Too many toys?? never!
