Old 04-26-2008, 07:16 AM
FatBoy's Avatar
Default 427 down on power
I have a 750cfm Holley on my 427, which was built by Southern Automotive and something isn't quite right with the engine. Although everything appears OK and it sounds fine, it just doesn't have the "go" that it should have and it's reluctant to rev.
I've checked the plugs and they are very clean and pale, maybe a little too pale. Fuel pressure is fine.
How do I know if the secondaries on my Holley are working OK?
I've removed the choke assemby and I'm running a K&N filter.
Any ideas ?
BTW, it has only run for a couple of very gentle hours.
Paul
Old 04-26-2008, 07:52 AM
Can you clarify your statement about not wanting to rev? Will it not pull past a certain point?
Is your carb mechanical or vacuum secondaries?
Old 04-26-2008, 08:17 AM
A very simple method is to disconnect/fasten-shut the secondaries and then take the car for a quick hard ride. If you don't notice a big difference, then you've found the problem. Has your car ever run better than it is running now, meaning is the lackluster performance a recent event? EDIT, oh I see it's only run for a couple of hours. You might want to give it a little more break in time before you get too involved.
Old 04-26-2008, 08:20 AM
Ron61's Avatar
Post
Also is the Holly a double pumper or not. If it has mechanical secondaries you can check to see if they open with the engine not running. Just pull the throttle back and watch to see if they open when it gets to the point the cam is set at. If it is a double pumper you will see gas squirt in the secondary end as well as the primary. And do you have the specs that tell what RPM the engine should make peak power and torque?
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-26-2008, 09:13 AM
FatBoy's Avatar
I'm sorry, I should have said, the secondaries are vacuum.
Old 04-26-2008, 09:19 AM
Do what I suggested. Wire the secondaries with a little string, wire, or twine so they won't open (just as if you had a very heavy spring controlling them so they never opened) and take it for a ride; get on the throttle hard, and see if it behaves exactly the same as before. If so, your secondaries are not opening.
Old 04-26-2008, 12:19 PM
Check the timing. If is retarded or erratic, pull the distributor and check whether you're losing the distributor drive gear.
Old 04-26-2008, 03:04 PM
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
Try to take it very scientifically, at first especially
- Verify with someone else on the throttle (not running) that the throttle is opening all the way
- Check the initial and total timing to ensure it is where you want it, and that it is advancing
- Review the firing order and make sure you have it correct
- Readjust the valves if you have solids
- Check how close the air cleaner lid is to the top of the carb
Dont ever discount bringing a good mechanic in for his ear as a backup plan, even if you only pay him to listen. Often it can go a long way
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
Old 04-26-2008, 03:43 PM
Cam shaft is retarded, like strictlypersonal alluded to...
Old 04-26-2008, 05:28 PM
Another suggestion to check if your secondaries are opening is a trick I learned years ago when racing . Take a piece of vacuum line slightly smaller in diameter than the secondary vacuum shaft ... about 1/8 " long and split it lengthwise and then put it on the shaft up as far up as it will go . Drive the car wide open and then look at the tubing . This will tell you not only if the secondaries are opening , but how far . Think of this as a travel indicator like is on a shock .
I also like all the other suggestions .... something like this can drive you crazy ... or in my case , crazier !!
Old 04-26-2008, 05:53 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
A paper clip can be used the same way.
Dave
Old 04-26-2008, 05:59 PM
Before:
After (if your secondaries are opening, that is...)
Old 04-26-2008, 07:07 PM
Johan's Avatar
Why not call Southern Automotive and ask them ? Did they build the carb ? What compression ratio ? Sounds more like a timing issue to me. What grade of gasoline are you running in it ?
Old 04-26-2008, 07:14 PM
767Jockey's Avatar
If you want to try the disconnect the secondaries method, it's only a "c" clip that holds the vacuum linkage to the secondary shaft. Just pop it off.
Old 04-26-2008, 07:17 PM
FB -- How much throttle pedal travel do you have from when your foot is just touching the pedal to when you have it pushed all the way to the floor (in inches)?
Old 04-26-2008, 08:04 PM
"Reluctant to rev", that description just doesn't sound like a carb issue to me.
Verbal or typed descriptions/symptoms are particularly difficult to get a handle on, by the way...
Of course if the secondaries aren't working that will reduce the horse power, but it should not make it reluctant to rev. THAT description does sound more like:
Plugged exhaust (not likely).
Retarded mechanical camshaft timing.
Retarded ignition timing, base or advance curve incorrect or sticking mechanical advance.
Along with plugged exhaust factor in valves sticking in the guides or grossly misadjusted, which could give the same symptoms as plugged/restricted exhaust.
Weak spark, can't fire the fuel properly.
Old 04-26-2008, 08:13 PM
But if we give Southern the benefit of the doubt that the engine was running right when they put it in the big wooden box, then the problem was in the installation. If that's the case, then what jumps to mind is: 1) Carb linkage, 2) Ignition Box & Spark, and 3) Exhaust (yeah, there could be an obstruction). Ignition timing shouldn't change, valve timing shouldn't change, plugs shouldn't be fouled, etc. on 2 hours worth of running.
Old 04-26-2008, 09:14 PM
PatBuckley's Avatar
...and inadequate fuel supply.
Old 04-27-2008, 12:52 AM
FatBoy's Avatar
Thanks guys for all your input.
The exhausts are fine i.e. not plugged.
The ignition is an MSD 6AL with an MSD billet distributor.
It starts up and ticks over just fine after a few seconds of warming up.
I'm inclined to think it is fuel starvation. The plugs are very clean (possibly too clean). I'm going to pull the carb today to make sure there isn't any dirt in it.
With regard to "reluctant to rev", by that I mean it lacks power and starts to miss above 3,000rpm.
Thanks again.
Paul
Old 04-27-2008, 01:11 AM
Starts to miss above 3000, whoa, big clue there, the mystery deepens, what does it all mean...
Any hint of a backfire condition (popping sound in the air cleaner/carb in particular), which is sometimes associated with a lean condition (among other things)?
