  #41 (permalink)
Old 07-15-2008, 05:32 PM
Cobra Make, Engine: Butler Racing/427 side oiler
By the by old boy; the next time you feel like showing of that big brain you may want to use spell check.
Steve
just had to pick this out seeing as it is MY post that you guys are pissssing at each other about.
I think "showing of" should of read "SHOWING OFF" LOL Now who needs spell check? HAHAHAHAH
  #42 (permalink)
Old 07-15-2008, 05:47 PM
Cobrabill's Avatar
Originally Posted by ERA649 View Post
Cobrabill,
If your car has gone thru 3 pick-ups something else is OBVIOUSLY wrong.Loose connection betweeen the wrench & the ground-maybe?
I know something is wrong but what exactly is it?
I'll tell you my story with a few tips.I'd be driving along,(loaded & un-loaded)and the car would shut off just you turned the key off.
But as soon as i hit the key,she would light right back up.This happened about 5 time spread over 2 months or so.Long enough spans prevent any aggressive troubleshooting.
Finally on a my way to a cruise night,it died and took a more than a few cranks to get it going.This happened about 2 blocks from my house.It should have been a hint for me to turn my butt around and head for home.(but,oh,no-not me!!)There's a cruise night happening!!I got it going and off to the show i went.
When it came time to leave,the car wouldn't start.So i flatbeded home.
I have to back up on you here for a second.At the time of this problem,the distributor was 4 years old and had about 4,000 miles on it.
So i employed standard trouble shooting techniques and discovered the lower magnet in the pick-up was cracked.And i also discovered that a little piece of"crap" was under it and acted as a fulcrum breaking the magnet.So the broken magnet operated o.k. for those 4 years but eventually the viberation widened the gap and the magnetic field went away.Hence the ride on the flatbed.
I cleaned everything,lubed everything the way it's supposed to be and replaced the pick-up.
Now here is a disclaimer:I have no recollection of gapping the p/u as others here have stated needs to be done.That doesn't mean i didn't do it.Anyways,it fired on the first crank and has been fine since.
To your problem:This is like a doctor diagnosing your illness over the phone.But here goes:
Verify that it does indeed need to be gapped.
Make sure the interior of the dizzy is sanitary.
Proper lubrication
Make sure there are no cracks/chips(what have you) in the pick-up
What about grounding issues?
And the first thing i would do is call MSD.And if there is a NHRA event near you,go to it and find the MSD trailer.Those guys are the real brains and will be able to answer ANYTHING you ask them.
I hope this helps.
  #43 (permalink)
Old 07-15-2008, 05:50 PM
Cobrabill's Avatar
Steve
If the best you can do is comment on my fat-finger typing,then indeed you are beaten,as only a loser would attempt such a lame deflection from the topic at hand.
One more thing-i never referred to spell check-genius.My reference to school was suggesting that you go back to school and learn what a steering wheel is used for.
Point*,set,match
Bye-bye Stevie
*Pun not intended
  #44 (permalink)
Old 07-15-2008, 06:55 PM
Default Cobrabill
Originally Posted by lovehamr View Post
Um, when did I say that? I said that "dwell" wasn't affected. You do know that there is a difference, right? Does that make the above statement 100% catagorically goofy? Or were you referring to my saying that it would take a long time for rubbing block wear to make an appreciable difference in timing? In which case the above statement would merely be lacking in accuracy and understanding. Man, this is like watching a liberal foist words into other people's mouths. I didn't say that I didn't have any point bounce, what I said was that I had no problems. And I believe that this may illustrate what everyone’s problem seems to be with this line of thought; you see, my point is NOT that points are a more precise or better way to trigger the MSD box. My point is that points are a reliable and still viable way in which to do this because most of us would never feel the difference anyway. Of course I know that your sensitive booty would pick up on those points in your distributor right away as you put on that second coat of wax!
First of all Cobrabill this is the post that I was referring to and I dont think thats you correct? so maybe zip it regarding me if you dont mind!
And this was my original post ..if you want to get into a pissing match do it elsewhere please and thanks!
Steve
First of all Cobrabill, this is the post that I was referring to and I don't think thats you correct?
This was originally my post regarding my ignition problem and seems to have been hijacked. If you want to get into a pissing match go elsewhere ...I was simply making a joke that 1 guy is telling another to use spell check and in the same sentence spells something wrong!
HAHAHAHAHA
Nough said!
  #45 (permalink)
Old 07-15-2008, 07:06 PM
lovehamr's Avatar
Stolen Avitar
Steve
Dhooooooooooooooo!!!!!!!!!!!!!!! Ya got me!!!!!!!!!!!!!!!!!
Steve
  #46 (permalink)
Old 07-15-2008, 07:38 PM
Cheers Lovehamr! LOL
  #47 (permalink)
Old 07-15-2008, 07:50 PM
lineslinger's Avatar
Point*,set,match
Bye-bye Stevie
*Pun not intended
It was a pretty good discussion on ignition until the self proclaimed "merchant of (cool?) hostility" got involved and decided to make it a tennis match.
Gee, what a surprise, a real first never seen before.
