Old 07-23-2008, 06:46 AM
Default 427 SO Timing/cooling fans
I have a 1966 SO with a lumpy cam (not extreme). I am running Dual Quads Holley 1850's. I started with Dual 390's but the carbs were defective from my engine builder so he replaced them with these. I have an MSD 6AL with Blaster Coil and and Ford Electronic Distributor, and a MSD 105 AMP one wire Alternator. I have disconnected the alternator while running and I am getting full current. All these things seem to be in working order.
Ever since I first started this newly rebuilt engine, I have had a lot of trouble getting it to idle when the cooling fans kick in. They are on a proper relay circuit, and all my grounds are new and in good shape. I have had to advance the timing to 18 initial just to compensate for the fans. I have done a fair bit of tuning to the carbs. It does idle pretty Ok now, but with this much advance it's getting hard to start when hot. The engine maybe has a total of 3 hrs-so it is not really broken in yet. Any ideas out there or has anyone experienced this "drag". For other reasons, I am thinking of switching to Weber stacks and wondered if this might help the idling or timing issues?
Thanks to one and all.
ForPaw
Old 07-23-2008, 11:04 PM
Does the idle get better when the fans turn back off? In other words, is there an exact relationship between the fans turning on and off and the idle getting better and worse?
This is a wierd one. Also can you give us your cam valve timing and lobe center degrees.
Old 07-23-2008, 11:12 PM
Yes, the idle improves once the fans shut off. I am pretty sure this is a Alt or Pulley issue. The MSD that I have only gets excited at 3000 and above. It does not put our enough at Idle to keep up the draw of the fans. Lobe seperation is 110. Not sure where on the cam card is the valve timing info. Now thinking of a different 1-wire Alt that puts out the amps I need at idle.
Thanks.
Old 07-24-2008, 12:21 AM
The electronics should be powered by the battery, not the alternator. The alternator merely charges the battery, so I'm not sure that a one-wire alt will make much difference. Methinks you are going to need to solve this problem the old fashioned way - eliminate one potential problem at a time. 1) connect a multimeter in series in the MSD hot lead and watch the voltage when the fan goes on and off, 2) same thing on the coil hot lead.
Good luck,
Brian
Old 07-24-2008, 02:09 AM
PANAVIA's Avatar
I think you need to measure voltage drop at idle (700-800) when the fans turn on. --
and again at 1000,1500,2000 RPM. There should be a initial V drop then the alt should kick in to prevent discharge of the battery.
The alternator sizing or index speed sounds like it is off and is not able to prevent discharge at idle.
--Steve
Old 07-24-2008, 05:55 AM
wtm442's Avatar
Beam Me Up Scottie
Is your battery OK? Maybe getting weak and ready to die?
Warren
Old 07-24-2008, 06:25 AM
The cause might be related to the torque required to drive the alternator when the fans kick on, the alternator can put a significant load on the engine even if it isn't keeping with load demand at that RPM. I would not change initial advance to solve the problem because you should not alter the curve assuming it's right in the first place. In the 70's they used to use a "throttle kicker" on engines to help offset A/c loads IE speed up the idle when the a/c was turned on. If power was cut to the a/c the engine would drop back to normal idle speed. These devices could be adjusted for idle speed in both on and off conditions and mounted to the carb at the idle stop. Perhaps you could use one from a salvage yard. I have a similar problem to yours but it is related to low voltage when the fan comes on. My problem is the voltage drops to a point where the fuel injectors don't function properly at 11.5 volts and the engine won't idle. My alternator is only a 50 amp Kubuto tractor unit that can't match the load at 2000 rpm.. Since you have carbs I would bet it is alternator drive load causing the problem.
Old 07-24-2008, 06:39 AM
I think your problem is alternator torque load on the engine. An alternator can put a significant drive load on the engine at high load conditions and actually cause it to slow the engine enough to cause a "rough idle". There was a device used by Ford and others in the pre fuel injection days called a "throttle kicker" that mounted to the carb and would speed up the idle when the a/c was turned on. It was a small solenoid that functioned as an idle stop that was higher set at a higher rpm when on and went back to normal idle when off. This can be done automatically on fuel injected engines with computer stepper motor idle control but not on a conventional carbed engines. Your ignition might potentially be a problem but even an MSD will function at lower primary voltages.
Old 07-24-2008, 07:15 AM
Default cooling fans
Thanks guys. I am almost certain it is an Alternator issue. Battery, etc working properly under load. I am going to try a different ALt, maybe a tough choice and see. The MSD don't charge till 3000 or so and idle on my engine is 1000. The initial V drop when the fans kick in kills the MSD box and I have to blip the throttle to keep it going. It has been a nasty gremlin to chase down but I am not going to let this one win.
Thanks for all your input. I will try and keep you posted.
Old 07-24-2008, 07:35 AM
Jerry Clayton's Avatar
I have seen a few cars that had the power for the fans wired thru the ignition switch--when the fans came on they and everything else suffered from low current. My method of solving these issues
NO reduced or underdrive pulleys----
Wire directly from alternator to relay for fans, use temp sender to ground the relay for operation, only run current to switch the relay thru ign. switch--this eliminates extra wire length amps the ign sw must carry and supplys the power for the fans direct when engine is running
A COMMON source of electric problems in vehicles and boats---bad grounds, remote battery locations, underdrive pulleys
Old 07-24-2008, 11:48 AM
undy's Avatar
There's another potential cause, a very weak idle too. A very lean idle mixture could be easily "upset" by the increased alternator load trying to keep the battery up to snuff.
Dave
Too many toys?? never!
Old 07-24-2008, 04:44 PM
Default Not correct info.
For Paw Let's start in the beginning. Do you know the Alt output?? Yes, No, maybe? You need an Alt that can keep all the electrical loads running and keep a min of 12.5 volts going to the battery at 1000 rpms. THE ALTENATOR is what powers all the loads once the motor is started. The battery is for staring the car and backup if the car idles for a long time with everything on,lights, cooling fans, blower motor, Msd module, Msd coil, electric fuel pump, etc. The batttery also absorbs the charging spikes from the ALT. What pulleys are you running? If they are not about 6" in diameter for the waterpump and crank pulley, they are TOO SMALL. The March system is underdriven and is good for racing and high rpm motors but not street driven low rpm cruiser. Here is some facts, MSD module draws about 16-20 amps, the coil draws about 6-10 amps, coolant fans, depending on how many from 10-30+ amps, electric fump pump 8-15 amps, Head lights and tail lights about 8-14 amps depending on what type, heater blower motor depending on speed, about 12-17 amps. With just the 6 thing a have here you are over most alt outputs at idle. An MSD system will not work below 10.4 volts. This is the steady drain on the system. Turning things on and off you are looking at spike loads of double to triple the running loads. This is why your car starts running rough. Not enough juice. A 100 amp min is the standard thing with normal pulleys. Most new car that are loaded are running 200 amp alts. Your playing with the timing is not helping. What is the CCA, cold cranking amps of the battery?? You should have something in the 800-1000 if possible. If you are going to idle the car for more than a minute or 2. Shut the motor off and just run the coolant fans. Lets a solid lifter motor run at idle is not good for the valve train IMO. Get the right pulleys for the car to start, make sure you have a large CCA battery, and replace the Alt with a min of 100 amp. A 140 would be better and cost about the same. Make sure the MSD system is hooked up directly to the battery for the red and black wires. This should help fix your problems. If you have any questions call me 732-254-3536 in the evening est time Rick Lake. Ps MAD Alt and PA Alt have real easy alts to swap into your car for plenty of charging. You may have to swap your amp gauge to a volt gauge with the power increase. There kits are 1 or 2 wire. Something to look into. Rick
Old 07-25-2008, 02:49 AM
Cobra Make, Engine: ERA #696, Ford 427/482 CO
The current draw for a MSD 6AL unit is 1 Amp/1000rpm. At idle this means a current draw of about 1 Amp.
A standard alternator is enough for most Cobras.
HOB
Old 07-25-2008, 03:48 AM
Default 5 amps at idle and 10.2 volts min
Hans-Olof Blom Hans if you go to the MSD site and check out Q&A you need 5 amps and 10.2 volt min. This doesn't include the coil. Do you know how big the compasitors need to be to put out on an HVC that makes 80-100,000 volts with 1 amp. About the size of a paint can. I have been running an MSD system for 10+ years on the cobra and another 15 years on my Trans-am. Number have posted above are very close to the real world numbers. Rick L. Ps I think you are saying that with the addition of 1,000 rpms the amps need to run the system increase 1 amp. It's more like 2-3 per 1,000 Also a 60 amp Atl can't power a ERA cobra with all the power on at idle with an MSD system. Alt putout is about 35-38 amps at idle. Msd, lights, blower motor, and 3 cooling fans, are over the max. I know from racing the car. Rick L.
Old 07-25-2008, 06:42 AM
Default cooling Fan update
Thanks for all the advice. Just to set the record straight, the wiring has been done with the best of breed components-everything from 0 gauge non-oxidising bat cables used in high end audio applications run directly to the Alt, ground run right to the block/starter, to all the ground straps one could think of to mig welded ground bolts on the chassis. I have had great advice from the best in the industry and have followed their advice and double checked to make sure that i have not missed anything. The carbs have been tuned within an inch of their miserable lives, and I am as close to the sweet spot as possible without going to a Dyno (These are going to be replaced by a Weber Stack system over the winter once I get this idle issue solved) So I have chased this on and off for over a year now and everything keeps pointing to the Alt. I guess MSD like any other manufacturer can goof every once in a while.
I have decided to order a new Reactor 100A alt to replace the MSD 105A I had. The main difference in the two is that the Reactor deliver full capacity at 1450 rpm vs MDS at 3000 and delivers more at 1000 rpm (idle for my engine) than any 1 wire on the market. I plan on measuring all the outputs once I get my parts and install them.
Rick, Alt output is 14.7. In one of my tests I unhooked the alt wire before starting and I did not have the problem when the fans kicked in. It might be something as simple as this Alt is malfunctioning. I have a 6.5 crank and larger water pump. I don't want to start changing Pulley ratios as this could start a chain reaction of water pump and cooling problems. The engine has been built to my specs by Southern Auto and they seem to know their stuff and have done these for many years now. This is a problem I have caused-I should have used their 65A alt supplied but i did not like the 3 wire system appearance and wanted something more advanced-that is pretty much where all this began. I did not realize that the 3000 rpm kick in on the MSD would be a problem. I am still holding that Alt ready to go if the Reactor does not work. All I need to do is get a voltage regulator or convert that to a one-wire. We'll see soon enough.
Randy
Old 07-25-2008, 09:18 AM
McD00's Avatar
Cobra Make, Engine: 931 mangled in parkinglot incident - traded for new house roof <sob>
Randy
Are you running a amp gauge? Sometimes they limit your current flow. I run a
regular ford 65 amp alternator and it powers my fans,lights and msd at the same time no problems. Sometimes all these fancy pants alternators are not the way to go.
Shelby just used a regular alternator and if it's good enough for him it's good enough for me.
Long live the Cobra!!
"...Just Shut the phuque up and Move on please..."
Old 07-25-2008, 03:59 PM
Default The problem is at idle and loads.
For Paw Randy Please read the info on MAD alt site and PA performance on there site. Yes some alt don't putout alot of amps at idle or 1,000 rpms. Some one wire systems need a min of 2,000 rpms before they start to charge the car after startup. IMO this is bad for both the electric system and the motor. Cold oil that is thick having to turn higher rpms than should be needed for a cold start. This is why you need a high cca battery. To be honest, 14.7 is high voltage for any system unless you are running a 16.0 volt system, then you are low. This sounds like a weak cell battery in your car. You need to have the battery tested for CCA and load. Most Alt deliver max output by 1,500 rpms. This is nothing new. The voltage regulator controls the output anyway. I run a 70 amp alt with all the same things you are running without any problems. For high ampage systems you should switch over to a voltage gauge. You need to find out what the ampage rate is first. Pulleys on the motor to water pump should be 1-1. pulley ratio should be about 3-1 on the alt to the other pulleys. Rick L.
Old 07-26-2008, 06:45 AM
Rick,
You are recommending a minimum of 100 Amps for the alternator and that 140 Amps would be lot better. Then you write that you are using a 70 Amps alternator?
I am using an MSD Digital-6 unit with a current draw of 0,7 Amps/1000rpm. The numbers for the MSD units are from MSD's specification. I assume that they know what they manufacture and sell. A minimum of 5 Amps is probably what is needed to be able to drive the car.
I have a standard 65 Amps Ford alternator which is what ERA recommends. I have no problems with the electrical system. Yes, the Amp-meter goes negative when my 3 cooling fans kicks in at idle. But that is one reason why I have a battery in the car.
HOB
Old 07-26-2008, 07:00 AM
Exactly the same for me, in all respects. If I'm sitting at a stop, with my two pusher fans and one puller fan spinning, and brake lights on, there will be a slight discharge. If I angle my heel over and kick the revs up a bit over a 1000 or so the ammeter needle swings back over.
Old 07-29-2008, 04:08 AM
Default It's not enough charging system for a long idle
Hans-Olof Blom Hans if you are smart and careful, you could run a 40 amp system on a cobra and a big battery. Would I want to?? NO way. ERA recommends a 60-70 amp Alt. This is just enough output for the ERA. When you add in opitional front fans, MSD ignition setup, and other things that drain the system you are short on charging at idle. This is with stock pulleys. I run 2 electric fuel pumps with relays, FI ECU, injectors, and the MSD 6AL with HVC coil. Racing the Alt can put out more amps than the car needs. The spikes of each system turning on and off is causing a blip in the car running. The MSD gets a miss. I am waiting for the return e-mail from MSD on the ampage needed for there system. ERA limits the charging ability with a 60 amp gauge. Can you use a 70 amp alt for the system, YES IMO. This is hard on a gauge designed for 60 amp limit. If you look at any car or truck from the last 20+ years NONE of them run amp gauges any more. They all run Volts.?? WHY? Because of the 80-200amp outputs in cars and trucks now. You would melt a amp gauge from the power going through it. Here is something else for you to think about, why does MSD have 2 12 gauge wires going to the msd box and you are to hook pos to the battery direct and ground to the main ground off the battery if possible? for .7 amps The box ecu may draw .7 amps the power end is a min of 5-7 amps plus. The coil is puting out 80-100,000 volts and around 2 -3 amps at the tower. The thing will knock your butt over the car from this power. You will be tasteing the power for the next 3 days. Yes I got zapped twice and it hurts I don't want to change the ERA amp meter to a volt meter but running the more power things in a cobra, this is the only safe way. There is nothing like letting the smoke out of a good wiring harness or gauge.Like siad before if you can idle a cobra for an hour, turn it off and it restarts you have no problems. If it will not start, better look for a jump or a hill to push start. That is if the battery has 10.-10.4 volts to fire the MSD box. I will be running a 100 or 120 amp with the next motor. I am adding air fans, cooler to the trans , cooler to the rearend. Both will need pumps to move the oil. More AMPS needed. Rick L.
