Old 10-06-2008, 08:15 AM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Camshaft and Webers
I would like to find out what most of you are running spec wise with your camshaft and your Webers (IDA 48),
Duration =
Lift =
LSA =
What RPM you feel the power =
Size of motor =
Old 10-06-2008, 04:58 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
I'm thinking of converting. What are your specs, and you're running a stroked FE?
Old 10-07-2008, 08:18 AM
FWB's Avatar
FWB FWB is offline
check this thread out...................
482" FE, w/58mm TWM - cam choice - opinoins please
Fred
Old 10-07-2008, 01:52 PM
priobe's Avatar
Thanks,
Just wanted to see what majority of the people were running as far as camshaft with Webers
Old 10-07-2008, 07:04 PM
rokndad's Avatar
Is it the general consensus, that 252/262 duration with .622 lift and 112 degree Lobe sep on a Hyd Roller is too much for Webers and will have that stumble off idle?
