Old 12-08-2008, 01:41 PM
priobe's Avatar
Default Header and sidepipe Gaskets
Hello,
I am looking for header and side pipe gaskets for a 427 FE.
What do you guys use for these gaskets.
Also, what bolts do you use for sealing the sidepipes for the headers.
I have tried SS bolts but they seems to break when I disassemble the side pipe.
Old 12-08-2008, 02:54 PM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
I used Remflex for the head to header gasket.
http://catalog.remflex.com/SearchRes...=9&Search.y=12
Cobra Make, Engine: Superformance aluminum427
Go to performance parts place an get the copper header gaskets for an FE motor and get the 1 inch header bolts, copper gaskets are the best.
Old 12-08-2008, 04:18 PM
priobe's Avatar
Is that the name of the place "performance parts place"
or do you mean A performance parts place.
Can you provide a web address.
Old 12-08-2008, 07:03 PM
Dwight's Avatar
Smile head gaskets
I tried the copper gaskets on a small block. They did not work. Leaked everywhere. I bought a set of laminated aluminum gaskets and they work great. No leaks. I've reused them a couple of time and still no leaks. I like them.
Dwight
P.S.
The header gasket worked so well that I bought a sheet of laminated aluminum (.048) and made my sidepipes to header gaskets. I made a pair for Lainhart's 427 Unique this summer. We have 180 miles on it so far but will not know about the gasket for a long time. Mine has 5,000 or 6,000 miles on them and are holding up to the pressure of a small block. (insert smillie face)
Old 12-08-2008, 07:10 PM
csx wnab's Avatar
Cobra Make, Engine: superformance/427 fe ford
Thumbs up gaskets
i use remflex. i even had them make the collector gaskets too. even got a partnumber so when i re-order for my customers or i , i just give them that.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
Old 12-09-2008, 04:05 AM
PANAVIA's Avatar
if you search under Graphite you will find some good gaskets for headers / exh.
Copper gaskets are expensive and easily messed up!
Old 12-09-2008, 05:05 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Earl's reusable gaskets have an aluminum frame with graphite inserts.....BEST I ever found!!
Old 12-09-2008, 05:31 AM
convincor's Avatar
I've tried the copper on mine, they leaked.
Currantly using graphite I got from Hooker. Two years with not leaks.
If I had to buy another set, I'd get Victor "nitroseal"
you can get them thru "CarQuest"
Here's part #'s http://www.network54.com/Forum/74182...rmance+Gaskets
Description- http://mahleclevite.com/p_performance_gaskets.asp
02 Super Duty 7.3L
Old 12-13-2008, 09:41 PM
Dominik's Avatar
Default none
I use no gasket, however, my header flanges are 3/8" thick and flat. I do apply a silicone-like sealer though.
The sidepipes are slip-in and fairly unrestrictive. If you have too much backpressure they may leak at the slip joint.
Dom
