Old 04-06-2009, 04:09 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default edelbrock heads with heasd studs and erson rockers
is there an issue when running head studs on the edelbrock fe heads with the erson rockers?, if so what is the fix pictures would be great. do you cut the head studs or mill the rockers?.
Old 04-06-2009, 05:33 PM
FWB's Avatar
FWB FWB is offline
an issue with height? oiling?
Old 04-06-2009, 06:20 PM
lovehamr's Avatar
Stolen Avitar
Wrench there shouldn't be any issues. In fact I think you'd have a hard time using bolts any time with these heads. When I threaded a bolt into a couple of holes beside the ex. ports there wasn't enough room for a socket to be used. Look right there beside the #6 ex. port, if not for the small diameter 12 point nut I don't think I'd have been able to torque it. These are from ARP.
Hope that helps, Steve
Old 04-07-2009, 04:24 AM
Yep - there is an issue. The stud sticks up far enough - sometimes - to hit the Erson rocker stand. Quickest fix is to mark the contact with a light install (no pushrods) and tap - and then mill (or grind) a clearance dimple/divot into the rocker stand. Takes only a few minutes and wont hurt a thing.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 04-07-2009, 04:42 AM
Default Use the tall valve covers
wrench87 I have shelby heads but had the same problem with alignment and clearance. Little grinding and a rubber mallet fixed that. My heads have special studs and nuts from a shelby block and the end stands needed to be modified for clearance of the head nuts. The stock valve covers are real tight. I have the cobrajet stock covers and they could rub in the back corners if a hadn't glued 2 thick cork gaskets together for clearance. I ended up going with the tall Leman valve cover and have no clearance issues. Lovehammer is right about needing 12 point nuts to get the nuts to not hit rockers. I gound down the washers for clearance to the mounts. Washer looks like this []. Works fine. I used ARP studs for my mounting hardware. If you are going to limit the oil going to the heads, nothing smaller than .080" oriface for good oiling. If you are going with a hydro camshaft and run hydro lifters that pump oil through them, get a set of Smith hollow pushrods. The oiling will help keep cool the contact point between the pushrod ball and the cup of the adjuster on the rocker. Run a HV pump and add 1 quart of oil past full. Make sure you get the correct length and ball and cup size for the setup. I think it's a 5/16" ball for the lifter and 3/8" cup for the adjuster. Check on this!!! Good luck Rick L. Ps make sure your oil return are clear of any gasket materials. The Felpro 1246 will cut off some of the return galleys.
Old 04-07-2009, 04:47 AM
Smile
thanks barry, that is what i was looking for.
Old 04-07-2009, 05:02 AM
convincor's Avatar
The "ARP/Edelbrock" bolts have small heads and only use a 9/16" socket.
No problems with clearance and they don't interfere with the Erson's.
02 Super Duty 7.3L
Old 04-08-2009, 06:36 PM
Ditto on what Barry said, my KC 482 has the studs ground down under the rocker shaft.
