Old 05-20-2009, 10:54 AM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Ride Height
Can someone post the ride height measurments
1. Oil pan to floor
2. Rear and front chassis to floor
3. floor to front wheel fender and rear wheel fender
Old 05-21-2009, 03:10 AM
Default Too many varibles
Priobe Which size tires are you running? Street or track? Do you have a lakewood bell housing and has it been trimmed on the bottom? Do you know your spring rates?
Here's mine for the track, 4 1/2" at the frame behind and before the tires. 4" at the bottom of the bellhousing, Lakewood.
2" of total travel from normal stance, 1" up and 1" down.
I am not running the stock springs and shocks in my car.
Every car is different and people look for a certain ride look, I think that is what you are looking for. Get the car where you like the look and then have the weights checked for balance of the car with you in the drivers seat. Depending on size of tire,17" or 15" this will also have some different hieghts onthe car. Try and give about 2" to the clearance of the tires going up, if you don't rub anything go to 1 1/2". I wouldn't go any less than this with street springs and shocks. Rick L.
Old 05-21-2009, 05:00 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I concur with Rick, My ride height is 4 inches at the lowest point. Your spring rates may need to be adjusted of you run out.
