Old 07-31-2001, 07:16 AM
mickmate's Avatar
Default FE aluminium flywheels
I see a couple on e-bay at the moment and wondered if anyone here was running them, liked, disliked or trusted them?
Cheers Nick
mickmate
http://www.actoncustom.com/
Old 07-31-2001, 08:37 AM
CSX 4027's Avatar
Default Flywheel
I run the Centerforce Aluminum. It is the only way to go. There is no need to have a 40lb flywheel in a Cobra. You are not launching a 3800lb car. The lighter the better for reving and downshifting. I suggest whatever brand you go with that you get the matching clutch set-up. This will eliminate any bolt pattern problems.......Steve
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 07-31-2001, 06:00 PM
mickmate's Avatar
Thanks Steve, any idea of the weight of the Al wheel. Do you have a radical cam and or smooth idle?
Cheers Nick
mickmate
Old 07-31-2001, 06:11 PM
CSX 4027's Avatar
Default Weight
I believe the centerforce is about 17lbs as opposed to the stock 40lb anchor. My cam is pretty radical, at the border of streetability.
Steve Sunshine
"Hurry Up And Live"
Old 07-31-2001, 06:23 PM
mickmate's Avatar
How's the idle?
mickmate
Old 07-31-2001, 06:32 PM
CSX 4027's Avatar
Default idle
1000-1200. I run 110 octane minimum.....It's a racecar with open exhaust. Don't worry about the aluminum flywheel, it will be fine with a street car.
Steve Sunshine
"Hurry Up And Live"
Old 08-01-2001, 12:59 PM
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
Mickmate,
I'm running a billet alum flywheel and a pretty radical cam also.
I can idle down around 1000 rpm and have no problem on the street.
Go for the aluminum, you'll be pleased with the responsiveness.
Later,
Old 08-09-2001, 11:08 PM
ram makes a nice billet alum for $450.00 Summit
Joe Bradburn
Old 08-10-2001, 07:56 PM
Default McLeod alluminum flywheels
I have a older Mcleod alluminum flywheel. It had a 11.5" steel heatsheild for a 11.5" clutch setup. It also has the bolt holes for a 11" pressureplate. McLeod is replacing all11.5 " clutches w/12" where bellhousing clearence is addiquit.They make a 12"pressureplate that fits the 11.5 bolt pattern( as explained to me Dark horse Performanse. My flywheel Was converted for $120 by McLeod Industries .I supose another brand would fit But the instock options the weekend of my need were not there without a 12" Heatsheild.The regular heatsheild replacement runs $85 if a used flywheel needed it.
Mike H
Old 11-01-2001, 11:15 AM
RickLee's Avatar
I bought the Weber Speed Alum flywheel on thats on ebay for $200.00 looks great
