Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By SF_SN888KE
Old 12-28-2009, 09:25 PM
SF_SN888KE's Avatar
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
Default Fuel Injector Service shop?
Looking for a Fuel Injector Service shop in the San Francisco bay area, (test, clean, service, replace o-rings, etc.). Looks like around $19-$25 per injector on the internet. Will consider shipping to good service shop. Any recommendations? Thanks.
jsaclay likes this.
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
Old 12-29-2009, 04:12 AM
Default Why??
SF_SN888KE Ron is there a problem with flow or idle issues. If you are running pumped gas and have good filters in the system. There should be no problems. If your system is a non return line than you could have problem with the ones on the ends of the deadheaded line. You can almost buy new ones for the price of rebuilding them. Try checking with one of the local speed shops. I have seen bags of 8 injectors going for $200.00 out of stock cars. There are cleaners that you can have a dealership use to clean the Injectors. BG is a good one. TEC that GM uses is about the best you can get. All you need to do is bring a quart of fuel and buy the CAN, no bottle. and have the dealership run this through the system with the fuel pump off and return line plugged. If this doesn't work and you feel an improvement with the car running, then try the injector service. I have used this system for years repairing drivibilities issues and it works about 95% of the time with removal of any thing. Good Luck Rick L.
