Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-11-2011, 12:49 PM
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
Default 482 Fuel Line, fuel pump, regulator and injector specs.
I have an aluminum 482 set up for port injection. Motor should make 700+ HP.
Use: Sunday driver plus an occasional track day.
Fuel pump: Mallory 650-11106M 83 GPH @ 40 PSI
Regulator: Mallory 4305M 30-100 psi.
Injectors: Accel 110-050848 47.8 lbs/hr @ 43.5 psi
Fuel lines: ERA #773 with 3/8" hard line to fuel tank. -6 AN hose return line regulator to tank, -6 AN lines from fuel pump to regulator and fuel rails
Is this spec. going to work for the intended use?
Drink no wine before its time
Old 12-11-2011, 01:57 PM
mickmate's Avatar
According to this you're gonna need 1/2" supply or -8AN.
Century Performance Center, Inc. :: Fuelish Tendencies - Understanding Fuel Pressure and Volume
mickmate
http://www.actoncustom.com/
Old 12-11-2011, 02:21 PM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
X2.......on above
Jack
XSSIVE .....
Old 12-12-2011, 04:35 AM
Default Been Running FI for 15 years
Lodiwino Peter calls my car a bastard car. It was built back in 97-98 no my own. Here's what I have done to the car for FI system. Have to remember that my motor(452) was supercharged to start and then went to a 482 size. Final motor will be a 498 with TWM setup. specs,
1,200 cfm accell throttle body, It's small but responce is great and control is smooth from idle to 6,200 rpms, ( hydro roller motor with beehive springs)
injectors 55 pound semens that where matched for flow.
Single plane dove manifold converted over to port injection. Side note have your manifold sent to Joe craine in Texas for port job of the runners. There is a 31 cfm different between the best and worse cylinder. price is about $400.00 with shipping. Manifold comes back looking like a jewel. All cylinders within 5 cfm when done. balance of cylinders is better too with A/F readings.
Fuel pumps, running 2 walbro 255 litres in the fuel tank. Each has own supply line, curcuit to relay and switch. Have 1 way check valves to stop flow back on other line. Have filters in both lines before and after pumps. Hardest part was routing them from tank to front of motor. I have a 2 1/2" supply lines and 1 3/8" return line. This is over kill but needed the extra pump and pressure with a blown motor. Need a MIn of 1/2 & 3/8 for a safe supply. IMO and tested over the years. You can get away with 3/8 & 5/16 return but don't recommend it. This is a street setup, not a track one. I don't like boosting up the pumps either. Mine have 39.5 psi at idle with vacuum control to the regulator and 46 psi at WOT. I pump alot of fuel around and it does warm up a little over a 20 minute run on the track. I also use from 3/4 to 1/2 tank of fuel level when racing. 3/4 "G" pulls the fuel away from my pumps at times and loose a little power, needs to be a 280 degree sweeper on the outside.
Fuel regulator is a paxton blue. These came out in 95 with vacuum control and adjustment. No problem been very happy with unit. No repairs to it yet.
MSD system for FI system with a crank triiger on the dampener. Need crank and camshaft sensor for an old FAST system. Coil is the High voltage "E" coil. Have had to replace rotors and caps over time from there poor contact issues and burning the rotor end.
I ran my fuel lines under the floor on the r/s of my car. I removed the riveted flor to do this. There is no easy way to run the lines and protect them from road debrie. Have a insolated clamp every 12" for support and to stop vibration of the lines.
The ECU is an old Speed-Pro setup with a 286 computor speed running and "N" calibrations using the TPS, Coolant sensor, O2 sensor, and AIT sensor. The first setup was done by a pro in PA. I have done small changes over time. It's not cheap but, IMO I think it's better than carbs in hot weather and easier on the motor for not washing down cylinder walls around turns. 7 years in a 452 motor size, now 8 years with a 482 motor size. The system is easy to expand. Side note, at WOT the cycle of my injectors is 68% The MAX you want to run injector is IMO 82-85%. YOU can cheat with high pressures and other trick but this puts alot more heat on the quad drivers in the ECU and shorten life too. Watch which injectors you run, Some are low ohms, others are high ohms. Make sure the ECU is up to carrying the load. Run + power to all injectors and use - side to ecu. Use 14 gauge wiring if possible, none of this 18-24 gauge stuff, same for MSD setup 10-12 gauge and direct hookups to battery, not starter soleniod. 95 amp charging system would help to. Need to change the amp meter over to a volt meter in the car also. Rick L.
Old 12-12-2011, 05:41 AM
undy's Avatar
WOW, a 700+ hp Sunday driver.
Just curious... I'm assuming you have a very big solid roller with some extremely big valved and well ported aluminum heads? To my knowledge, that's the only way you're going to make 700 NA hp with a wedged head 482" FE... That sure doesn't lend itself to docile cruising.
Too many toys?? never!
Old 12-12-2011, 09:06 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
A 5-10 PSI pressure drop is really a non issue on a EFI engine. Mickmate's calcs are for carburated engine, and that's a totally different animal.
I would also add, it's more important that the return line be of sufficient size on an EFI engine in order for the regulator to be able to return enough fuel at an idle to function.
Here's how to test if your lines are of adequate size. With the engine off, run the fuel pumps and turn the regulator all of the way down. How low will it go? That's the maximum back pressure of the return line( it may be less, and the regulator is the restriction), and if the supply line is of the same size, length, and roughly the same amount and quality of bends, you can assume it's equally restrictive and adding that much work to the pump.
Old 12-12-2011, 09:55 AM
Default 700 hp
2ND that, I have 64 lb/hr injectors making a little over 800 @ 45 PSI, it would be hard to make 700 with that size injector. I had an engine that made 734 but it had 52 lb/hr injectors @50 PSI.
