-   Fuel Injection & Tuning (http://www.clubcobra.com/forums/fuel-injection-tuning/)
-   -   locating an O2 sensor in a side pipe (http://www.clubcobra.com/forums/fuel-injection-tuning/143700-locating-o2-sensor-side-pipe.html)
maui 06-05-2020 11:53 AM
I did a search, can't find any graceful examples here. What has been successfully done? I called the Holley Sniper EFI tech line and they stick to the instructions to the letter, liability wise I don't blame them. Anyone install the O2 sensor in a side pipe, in a non recommended position like slightly down or under the car? Were there issues or did it workout?
twobjshelbys 06-05-2020 12:46 PM
Mine was on the passenger side about a foot downstream from where the 4 header tubes join the muffler. It was almost horizontal. It's not an ideal position but there isn't anyplace better. This way you get the blending of 4 cylinders. At least there is was mostly out of the way.
Others have put it in one of header tubes but you're only sampling one cylinder...
ERA 626 06-05-2020 01:00 PM
I put mine on the passenger side right past where the 4 pipes join at about 4 oclock
maui 06-05-2020 01:07 PM
thanks for the replies,
I would think that sampling one cylinder would be less than optimal as not all 8 have the same A/F ratio unless you're going with port injection, and even then you have to have individual O2 sensors to really know.
so in both cases the lead is under the car and can't be easily seen, and still works fine, correct?
twobjshelbys 06-05-2020 01:15 PM
Yes, that was the point in mentioning it. Some DFI systems can sample two sensors but the Accel folks said one side is adequate.
Don't put two on one side!!! The modern systems have two on each side - one before and after the catalytic converter. They are used to measure the presence and effectiveness of the cat.
Yes. ERA626 sounds like his is where mine was.
bobcowan 06-05-2020 01:33 PM
Mine are also about 4 o'clock.
They were initially installed pointed toward the front of the car. But they quickly failed. Like in about 200 miles or so. Now they are turned around, pointed towards the back of the car. They've been functioning fine for over 6,000 miles.
https://i.imgur.com/8jNqtfC.jpg
https://i.imgur.com/VS6raLM.jpg
olddog 06-05-2020 02:04 PM
Well it kind of depends on what you are installing and why.
If you are installing a wide band just to connect to a gauge to monitor AFR, say with a Carb, then definitely install it after the four pipes merge into one pipe, as far down as the side pipe will allow.
OEM EFI experts used to make a big deal out of the narrow band O2 should be like 15 - 20" from the head. One of the reasons is that OEM EFI systems are constantly testing the engine. It will lean a cylinder out and watch for the O2 to change. The distance to the O2 sensor impacts the response time. Also the closer the O2 to the engine, the quicker the O2 heats up to give a reading on a cold start. For these reasons and more, many experts recommended to put the O2 into a single pipe, rather than after the collector on long headers. Others claim they have figured out how to compensate for the longer distance, so it is only how fast the O2 heats up. If you have a good tune then it will be very close to the commanded AFR in open loop, so even that does not matter.
There is more, but I doubt you want to know, and I'm too lazy to type it all.
t walgamuth 06-05-2020 03:23 PM
The last one is about where mine is but the top comes inside the footwell.
eschaider 06-05-2020 04:53 PM
+1 on what olddog said. There is a measurable delay in time required to sense a change in AFR the farther from the port the sensor is placed. Some EFI systems have a compensation factor you can adjust in the tuning software but there is no way to change the fact the sensor is slower to respond the farther from the exhaust port that you put it.
One of the fixes for the problem is to take the flange on the headers (between the engine and side pipes) and move the flange back an inch or so. After you have moved the flange back make a stainless square block that will fit between the headers and the side pipes. Mill out the center of the block leaving a large square opening. Weld an O2 sensor bung in a horizontal position.
Assemble the headers and side pipes with the stainless block and gaskets between them. Tighten everything up, screw in your sensor of choice and go for it! Your sensor will be where the calibration engineers wanted it, in terms of distance from the exhaust port so warm up and signal delay will be "normal" in calibration engineer terms.
A nice benefit of this approach is the sensor is protected from road debris thrown up by the front tires and the side pipes look "normal" without any wires or plumbing going into the collector area.
If you haven't chosen a Wideband yet definitely look at 14 Point Seven (<= clickable) wide band offerings. Although they use the same Bosch sensors you can get anywhere they have the absolute fastest electronics for sensor signal to ECU time available anywhere today. Their pricing is quite competitive also.
Ed
fastd 06-05-2020 05:05 PM
Believe it’s supposed to be more like 2 o’clock not 4 o’clock to protect from moisture
eschaider 06-05-2020 05:24 PM
Most of the sensor manufacturers will caution us about sensor placement that allows moisture to collect in the sensor. They will encourage either a 3 o'clock or 9 o'clock sensor positioning. A 2 o'clock or a 10 o'clock sensor positioning will also work but a 4 o'clock or 8 o'clock sensor positioning is not recommended because of the potential to collect water. The water comes from condensation in the exhaust system during cold start and potentially other times. Water in your O2 sensor will wreak havoc on the sensor and eventually kill it.
You can also kill sensors by positioning them closer than the typically recommended 12 inch minimum distance from the exhaust port or by positioning the sensor so that the sensing element is pointing into the outbound exhaust gas flow. You will be best served with the sensor positioned normal to (at right angles) the exhaust gas flow and somewhere between 12 to 18 inches from the exhaust port at 3 o'clock or 9 o'clock in the exhaust pipe.
Ed
bobcowan 06-05-2020 09:01 PM
Originally Posted by eschaider (Post 1477962)
One of the fixes for the problem is to take the flange on the headers (between the engine and side pipes) and move the flange back an inch. After you have moved the flange back make a stainless square block that will fit between the headers and the side pipes. Mill out the center of the block leaving a large square opening. Weld an O2 sensor bung in a horizontal position.
Assemble the headers and side pipes with the stainless block and gaskets between them. Tighten everything up, screw in your sensor of choice and go for it! Your sensorial be where the calibration engineers wanted it, in terms of distance from the exhaust port so warm up and signal delay will be "normal" in calibration engineer terms.
Ed
I can't imagine this would be good for header performance. I'm guessing that you'd loose all or most of your pulse vacuum.
Ed
I have read this before. I think I've even said this before. And it makes logical and engineering sense. The sensor pictured above has been there more than 6K miles. No codes, so I'm guessing they're working OK.
My FFR had the sensors in the same place for about 12 years without any problems.
I suspect it's not as big of an issue as we think it is.
The advantage to placing the sensor in the collector is that it samples four tubes/cylinders. Yes, it's kind of a long way from the chamber. But the computer can easily compensate for that and give a good accurate signal.
olddog 06-05-2020 10:27 PM
It's not a big deal in a Cobra that is almost never driven in the rain and even less likely to sit outside overnight in the winter. Try it in a daily driver when you can watch water spewing out of the exhaust pipes and you will get a different result.
If you have a good intake and header design, all four cylinders will be the same. If this were not the case the leanest cylinder would get toasted. So the one pipe verses four pipes, although not ideal, is not nearly as big of a deal as too great of a distance. Exactly how far is too far, depends on what criteria you are using.
Let me talk process control in general. The computer can only control the process it is connected to. You cannot make it respond any faster than the process is designed. When tuning a PI control loop the gains can be calculated by: proportional gain Pg = Pk / (Tc * To) where Pk is the process gain (ratio of measurement change / output change); Tc is the time constant, and To is the dead time (time it takes the measurement to see an output bump). The absolute worst thing you can design into any process is a long dead time. With a one minute dead time the control variable is changing for a minute, but the computer cannot see it and react to it until that minute is up. As the controller makes the correction to come back to set point, there is the same dead time issue causing overshoot. This forces you to use a smaller gain to keep the loop from going into an ever increasing osculation that spirals out of control. Thus you have massively increased the response time of the control loop.
Now EFI does not use traditional P or PI or PID controllers, but the concept still applies. EFI control is brilliantly different, and it responds better in some ways. It rapidly makes ballpark corrections and very slowly dials in to spot on. It also handles an extremely noisy measurement from the O2 sensor.
eschaider 06-06-2020 02:38 AM
Bob,
The arrival of the negative pressure wave at the exhaust port, what you identify as pulse vacuum, will still occur, it's timing will just be too early to provide any improved midrange scavenging. The early arrival is exclusively due to the short length of the header pipe and the reduced time to travel the distance between the valve and the newly created O2 sensor chamber between the header and the side pipe. While that sounds bad, and in fairness it is not good, the length of our side pipes tunes that pulse to a very low rpm because of their extraordinary primary length.
That low rpm tuning will enhance low speed engine torque at the expense of mid range and higher rpm torque. That said, it is possible our side pipes may produce no more power than a good low restriction under car exhaust. The reason that they may not, primary length not withstanding, is that the original side pipe mufflers that came with our cars tend to be fairly restrictive.
There are several aftermarket side pipe alternatives that look less restrictive than most original mufflers. As good as our side pipes look, a good, large diameter undercar exhaust with more traditional muffler geometry may produce a net power increase.
Bottom line I suspect, but don't have data to support the suspicion, that the chamber for the O2 sensor (between the header and the side pipe) will not materially, effect engine power enough that the driver can feel it.
It is in all likeliness because of what Rick (olddog) was suggesting about usage frequency. The more frequently we operate the car the more frequently the sensor gets exposed to water condensation from a cold engine start.
At first glance, this does not seem to be a big deal however most O2 sensors do not just fail they tend to fade or drift with age getting increasingly less accurate until they finally give up the ghost and we need to replace them.
Along the way to giving up the ghost the AFR or lambda reading they communicate to the ECU results in a progressively incorrect AFR/lambda performance compared to the commanded target in the tune. On a high horsepower engine this mis-communication can bring on incipient detonation which the driver cannot hear but the pistons can feel.
The pic below is of a piston from an engine with 30K+ miles on it's tune that did not smoke but had become lazy. I am not trying to be cute, the engine still made significant power but it was becoming tless responsive to small changes in throttle position — it wasn't as much fun to drive.
https://www.modularfords.com/attachm...9&d=1456175661
When it was torn down all eight pistons looked the same. All pistons had all three rings still in place although the top rings were pretty beat up. The top has been removed in the photo above. Notice how nice the skirt still looks, not withstanding the damages to the ring lands.
Although they are bit pricier, the NGK sensors have an interesting attribute that depending on your perspective is either good or bad. That attribute is that the NGK sensor will not drift. There is more to this story than what it appears to be. As the NGK sensor begins to deteriorate instead of drifting it totally fails sending you a clear signal it is time for replacement.
One of the nice attributes of the 14 Point 7 wide band sensors, other than their stunning speed, is that they continually compensate for the sensor drift attributable to age, water, over heating etc. Eventually they will also need replacement but your AFR/lambda readings will be accurate all the way to the end of the line — sort of a poor man's NGK.
You're right about the newer ECU's being able to offer some drift compensation, Bob. However, as Rick has already pointed out this delayed reporting of the presence of oxygen in the exhaust (associated with a sensor that is far from the exhaust port) will produce a less desirable driving experience because the engine is not being properly fueled in real time.
Virtually all EFI systems today use some variation of fuel trim tables that over time essentially "learn" what the engine wants for fueling and eventually produce a pretty good driving experience. This is true until something like the O2 sensor begins to drift and the fuel trim tables are off because the O2 sensor is mis-reporting the actual oxygen content in the exhaust. This is further aggravated by a tardy sensor that is late in reporting how rich or lean the exhaust is. Both whoopses affect proper injector pulse width calculations and the ECU's ability to properly fuel the engine becomes progressively worse.
One of the really nice attributes of the 14 Point 7 sensors is their stunning speed. Properly placed in the exhaust system they produce the best real time reporting of oxygen in the exhaust allowing the EFI system to track the commanded AFR / lambda the tuner has programmed into the EFI system at the highest fidelity level the EFI system is capable of.
In general EFI does some pretty amazing things operationally, compared to carbs and distributors — even when we hobble it by not optimizing the installation. When we do optimize the installation the engine performance is for all intents and purposes, untouchable.
Ed
MKS427 06-07-2020 03:05 PM
One option, I have not seen mentioned, is a double collector at the side pipe flange. This does require new headers, but you are sampling 4 cylinders within 18" of the heads.
Mine came from GP Headers. The sensor is positioned a 6 o'clock, but it is on a downhill run. I believe FFR Coyote headers have the double collector.
maui 06-09-2020 05:50 PM
lots of good stuff here, thank you.
as mentioned it was a conversation with the Holley tech dept that lead me to ask here. I completely respect the limitations a tech line has to operate by.
Looking at Bob's installation I ordered a 45 degree bung which will be a better candidate to weld in then the supplied clamp on boss Holley provided. Summit has it listed as steel, not stainless, fine either way.
I'll keep an eye on the sensor degrading. The pictures Ed posted was interesting. With the ring land opened up like that I am surprised the ring had much of any sealing ability and didn't take out the bore.
As for making a stainless steel block I guess I'm not really seeing the advantage over welding a bung in the same spot. I'd like to understand the square shaped port if you could give more detail.
Gaz64 06-09-2020 05:59 PM
Originally Posted by eschaider (Post 1477981)
Bob,
When it was torn down all eight pistons looked the same. All pistons had all three rings still in place although the top rings were pretty beat up. The top ring looks like it is missing in the photo above. It is not, it is actually still there! Notice how nice the skirt still looks, not withstanding the damages to the ring lands.
Ed
Any more pics of those pistons Ed?
I find it hard to believe the top ring is fitted to that piston, I can't see it.
The engine must have pinging a lot, intermittently.
eschaider 06-10-2020 01:53 AM
That was the only one I kept, Gary. They all looked about the same. The top ring is no longer in the land in that pic. I know, the visual is stunning. Amazingly this engine did not smoke and still had significant power. The second ring was apparently doing the majority of the heavy lifting — not something it was designed for.
Unbelievably the detonation was undetectable to the ear while driving the car, windows up or windows down. It was however, just enough to overheat the crown and top land but not enough to push out a chunk of piston or burn through a ring. The other thing worthy of noting was the engine literally ran 30K+ miles with this condition after being tuned by a big name shop.
The tune was reportedly done for max power. The engine did not have any knock detection or correction protections / capabilities because it was an OEM ECU. The car was a supercharged 03 Cobra which made the engine more detonation prone. I believe it would be difficult but not impossible to do the same thing with an n/a engine — but who wants to test those sorts of waters.
The old lean is mean quip sounds good but does not play well in the real world. I always like to shoot for a whisker on the fat side just for good measure. That does not produce any meaningful decrease in power but it does produce a significant improvement in engine service life.
Ed
p.s. Almost forgot to mention, the second and oil lands were both tightened up a bit . The second ring was quite tight essentially keeping it from freely rotating on the piston. The oil land was also slightly pinched but not enough to limit ring rotation or compromise oil control yet.
olddog 06-10-2020 07:20 AM
I would have guessed Laughing gas and blown as my second guess.
Back in 89 to 93 years, Ford commanded about a 10:1 AFR at WOT. Chip makers were commanding 12:1 AFR and getting about 30 Hp gain. They stated must use premium fuel with the chip installed. Those who didn't read and head often ended up with pistons like you pictured.
In the ovoid detonation world of tuning, pulling timing or going rich is the only tools. Timing kills more Hp than going richer. Obviously fuel and combustion chamber matter but the tuner has no control over those. My guess is that the tuner tuned the engine with a good premium fuel and the owner bought low octane fuel. He didn't hear a ping and thought he got away with it, and he did for a while. Now he thinks it was the tunner's fault. The tuners should make you sign a paper acknowledging that you were warned that you must run a premium fuel.
ERA 626 06-10-2020 11:14 AM
Most of the sensor manufacturers will caution us about sensor placement that allows moisture to collect in the sensor. They will encourage either a 3 o'clock or 9 o'clock sensor positioning. A 2 o'clock or a 10 o'clock sensor positioning will also work but a 4 o'clock or 8 o'clock sensor positioning is not recommended because of the potential to collect water. The water comes from condensation in the exhaust suystem during cold start and potentially other times. Water in your O2 sensor will wreak havoc on the sensor and eventually kill it.
You can also kill sensors by positioning them closer than the typical recommended 12 inch minimum distance from the exhaust port or by positioning the sensor so that the sensing element is positioned so as to be pointing into the outbound exhaust gas flow. You will be best served with the sensor positioned normal to (at right angles) the exhaust gas flow and somewhere between 12 to 18 inches from the exhaust port at 3 o'clock or 9 o'clock in the exhaust pipe.
Ed
mega squirt says 4:00 is fine... if you got water in your pipe at 4:00 you have a lot more to worry about other than a o2 sensor...
