Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 02-06-2007, 09:46 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Default Fuel Pump
What type of Fuel pumps are you using? I am using an Aeromotive and it is LARGE and I'm having a hard time finding a place to fit it.
Old 02-06-2007, 10:36 PM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Depends on what you need for pumping capacity. How much do you need to run in gallons per hour or liters per hour (gph/lph) and at what pressure?
DonC
Old 02-06-2007, 10:55 PM
Rwillia4's Avatar
All good questions of which I wish I knew the answers. It is for a TWM Fuel Injected 427W with a FAST system. So volume is not really as important as fuel pressure. I dont know what the worign pressure is yet (as the engine is stilln ot in the car)
Old 02-06-2007, 11:05 PM
DonC's Avatar
Most FI systems run in the 40 or 45 psi range and there are a lot of pumps out there that will do that. Take a look at the Mallory 4261FI which is rated at 255lph/67gph at 40 psi just for starters. It's about 6 inches long and about1 1/2 inches in dia.
DonC
Old 02-07-2007, 07:03 AM
Rwillia4's Avatar
I have a fuel pump, I just need to find a place to fit in in the confines of a BDR.The aeromotive pump was supplied with the FI "kit" I purchased. It wil be a tight fit in the rear in front of the fuel tank and behind the diff. (I started a similair "location" thread under the BDR page)
Old 02-07-2007, 07:14 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default I used the Malory pump supplied by Mass Flo.
[IMG][/IMG]
