Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 09-04-2008, 09:30 AM
Default Ignition on FI
I have been noticing a lot of cars with FI that are running distributors. What am I missing? All of the FI systems we run on sand cars use coil packs which can be mounted in any place within the engine bay. What is the purpose of keeping the distributor and limiting the timing options?
Old 09-04-2008, 09:53 AM
philminotti's Avatar
Several reasons, IMO.
1. Distributorless doesn't look right.
2. Cost. Also, you need an oil pump drive distributor plug that also generates a cam sync signal (for sequential efi)
3. See #1.
4. Distributors work just fine.
Old 09-04-2008, 02:10 PM
Like Phil said, unless you go dry-sump you don't eliminate the biggest failure point which is the pump drive (cam gear). If your distributor is set up right it will not cause problems with timing, but it should checked for index.
To do it right your looking at $3k minimum, I can buy a lot of spare distributors for that kind of money. Not to mention I'll probably not notice the difference between 634hp and 640hp.
And it looks right for what that's worth...
Old 09-04-2008, 04:18 PM
Default There is a little more than that
diethelm It depends on which FI system you are looking at. I run a F.A.S.T older system. I have 60 degrees of timing. How much more do you want? 90% of the FI systems need a crank trigger and a cam sensor. Cam sensor tells the motor when to fire the injectors either in batch or the start of sequential order. The crank sensor is for the timing of the motor. My crank timing is 55 degrees before TDC. Others may vary. Unless you are a dry sump motor, you will still fine it easier to go with the distributor firing the plugs. Moldec has the 4 coils. I don't know alot about this FI system but like every system there are limits and extra bells and whistles. My system has timing and fuel control for each cylinder. Most don't. This helps the weaker cylinders to balance out the motor better. 4 coils make more spark and also wasted spark to each cylinder. My HVC coil works harder. Bottom line, it's what look you are looking for. Rick L. Ps I left out the price range from $1,000.00- $9,000.00 depending on intake, injectors,sensors, throttlebody, or throttlebodies, ( like TWM setup ) ECU and wiring for the car. If you go FI, make sure you are going with a wide range O2 sensor setup.
Old 09-04-2008, 04:59 PM
Interesting responses. On the sand cars we run a crank trigger but do not use a cam sensor. You can run the crank trigger off the dampner in the front. Also, once we tune on the dyno, we pull and plug the o2 sensor as it is not used. Most everyone used to run electromotive and has now moved to Fast. A long time ago we used Haltec with distributors but found on the same engine, significant hp and torque pick up with coil packs. I still need to understand how you can have as much control with a distributor over coil packs especially when it comes to limiting rpm and shutting down the engine in cases of temp, oil pressure and other issues.
With respect to looks, I suspect FI in no way looks like an original carb setup and the coil packs can be hidden. A set of 8 coil packs is 180 bucks so I am not sure how that is more expensive than an MSD spark box and a distributor set up.
In any event, thanks for the input, I am thinking of building a car but need to do more research.
Old 09-04-2008, 05:09 PM
Depends on the system:
www.mass-floefi.com
Can't do much to hide the fuel rails though...
