Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 01-26-2009, 02:17 PM
Rick Parker's Avatar
Default Temp gauge help
I am attempting to locate the temprature gauge sending unit for a 2005 Mustang GT with 4.6 SOHC engine. I have tried all the search engines without sucess in an attempt to find its location. The gauge is not functioning at all. Where is it located on the engine specifically. What is entailed to R&R it. Thanks in advance
Rick
Old 01-26-2009, 02:50 PM
FWB's Avatar
FWB FWB is offline
there are two on your motor they are next to the thermostat hsg and on the other side of the alternator bracket, kinda same position. i believe they are 19mm hex, try a line wrench
fred
Old 01-26-2009, 02:52 PM
FWB's Avatar
FWB FWB is offline
not sure which is for the guage, they are called ECT's.
fred
Old 01-26-2009, 07:48 PM
The two large hoses exit the top front of the engine. Drivers side goes to bottom LH side of radiator, passenger side goes to top of RH side. No sensors anywhere. Someone said under the intake manifold, another individual said at rear of block. I knew ther was a reason why I didn't like computor controlled engines???
Rick
