Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
Old 02-12-2011, 01:37 PM
BMK's Avatar
BMK BMK is offline
Cobra Make & Engine: Shelby alum 468 block
Lightbulb Trumpet filter
Hi all,
I currently have foam filters pulled over the trumpets and wondering if anyone had an idea of a supplier of a filter. I also have tea strainers that I swap on but have not used foam with them, just the wire strainer - they are ideal on track days stopping small stones going down the throats. The trumpets are held on with 3/14 stainless bolts.
But any alternatives would be ideal.
Bernie
Bernie Knight
Old 02-12-2011, 07:29 PM
Dwight's Avatar
I contributed to CC in 2006
I have in the past contributed to CC
Cobra Make & Engine: RCR GT 40 & 1966 Fairlane 390 5 speed
Smile
Bernie, I am searching for better filters for my GT 40 setup. There are several threads on the GT 40 about this.
Do a search on weber filters or trumpets
http://www.gt40s.com/forum/
Dwight
I'm still looking. I may build my own. But I hate to hide my injection system.
Old 02-12-2011, 08:33 PM
OZCOBRA's Avatar
Cobra Make & Engine: Homebush,B2 Windsor 445
Originally Posted by Dwight View Post
As good as these look they do restrict the flow on a bell top trumpet as it stops the flow over the edge and changes the flow pattern through the mouth....an air box surrounding away from the bell top with some form of panel or pod filter would be an ideal!!
Old 02-13-2011, 05:36 AM
Dwight's Avatar
Smile
I've seen boxes with a flat filter on the top and others with a tradition filter with a plate on the top, like the carb filters.
One with plexglass so you could see the injection system. A little bit of both worlds.
Still looking.
Dwight
Old 02-22-2011, 10:50 AM
BMK's Avatar
BMK BMK is offline
dWight
Is the Gt40 in the photo your vehicle or do you know where the mesh filter tops are available? They would be ideal as my concern is stopping the stones/gravel going down...
Bernie
Bernie Knight
Old 02-22-2011, 02:43 PM
bobcowan's Avatar
Cobra Make & Engine: Backdraft, supercharged Coyote
Originally Posted by BMK View Post
Hi all,
Bernie
The tea strainers cost me 100hp on the dyno. Most of the restriction comes from the rubber lip, but some does come from the foam. On the track, I use open stacks.
A few years ago, I got the bright idea to replace the foam with gauze filter element from K&N. The engine ate 3 of them. The rest went into the trash.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 02-22-2011, 02:50 PM
Dwight's Avatar
Smile
Bernie
yes that is my GT 40. I'll with check and see if I can find out were Allan bought them.
Dwight
Old 02-22-2011, 04:25 PM
BMK's Avatar
BMK BMK is offline
Thanks Dwight much appreciated
bernie
Bernie Knight
Old 02-23-2011, 02:53 AM
Dwight's Avatar
Smile trumpets filters
Allan said they came with the set up but he has seen them in the Pegasus Racing catalogs.
Dwight
Old 03-02-2011, 01:19 AM
BMK's Avatar
BMK BMK is offline
This is the current setup on the GT40
Bernie Knight
Old 03-02-2011, 01:20 AM
BMK's Avatar
BMK BMK is offline
Bernie Knight
Old 03-02-2011, 11:10 AM
Pumpkin's Avatar
Cobra Make & Engine: VSE #24, 427cu, 6 spd, 550hp.
Default trumpet screen/filters
Hi,
I run webers (ida48) and have obtained my screen filters from Pierce Manifolds in Gilroy CA.
Glenn
Old 03-02-2011, 12:26 PM
Rick Parker's Avatar
Cobra Make & Engine: NAF 289 Slabside Early Comp Car with 289 Webers and all the goodies. Cancelling the efforts of several Priuses
The largest share of the volume of air into the stacks comes not from directly above but from the side. The OEM stacks with the non rounded edge shears the air as it is drawn into the stack. The others with a more rounded edge promote better flow. In my opinion the placement of any individual screens (such as the sanwiched foam OEM type) or the more recent production "Stainless Mesh" type which have a rubber band around the perimeter and secure themselves around the edge of the individual stack will cause a disruption of air flow at the outer edge and a resulting reduction in performance. This may only become really appearant at WOT because up to that point anything can be compensated for by further depression of the throttle, but will be felt to a minor degree throughout the operating range. Admittedly a big part of the mystic of the Webers is their no holds barred appearance, but the box type filters, such as those from TWM and others will most likely provide a better overall package because there is more filtering area and a larger "filtered plenum" from which the individual stacks pull the air. You dont see individual filters on the injector stacks on F1 cars, there is a reason.
Old 03-14-2011, 03:00 AM
BMK's Avatar
BMK BMK is offline
Thanks for your help and advice.
Bernie
Bernie Knight
Old 03-14-2011, 03:39 AM
Gaz64's Avatar
A plenum box (like K&N for sprintcars) offers multiple times the filter area per cylinder with a volume of filtered air for each cylinder to draw from unrestricted.
No single airfilter can deliver enough airflow that IS clean.
Some only filter down to .009.
That's still going to sandblast your motor.
Old 03-28-2011, 07:36 PM
Alan P.'s Avatar
Cobra Make & Engine: Superformance
Thumbs up
Bill's Filters are some of the best available.
We've used them on our GT40R's with both Webers and fuel injection and have no complaints.
http://www.bills-b-racing.com/
Fast cars don't make fast drivers
Old 03-28-2011, 10:58 PM
CHANMADD's Avatar
Cobra Make & Engine: 1989 KCC from South Africa Right Hand Drive
I always thought that the area under the rear window was a plenum.
Why not get some nice filter in the intake vents above the rear wheels?
Then it will catch any stones coming in and a plate of lexan or the like cut out fit around the trumpets with a little foam seal around each trumpet and to the engine cover...??
Old 03-08-2012, 02:50 PM
PoppyMod's Avatar
Cobra Make & Engine: Ford 289
dWight
Bernie
Hi,
Google "Bill Hirsch". I'm running his filters on my Webers. He'll do custom colors, as well.
Ken
Severna Park, Md
