Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
Closed Thread
Old 07-02-2006, 01:10 PM
oliver350's Avatar
Banned
Default GT40 at last!!
Just got her home! I'm selling my shelby's ...this thing takes the cake!!
oliver
Old 07-02-2006, 01:49 PM
trularin's Avatar
Member of the north
I contributed to CC in 2006
I have in the past contributed to CC
Cobra Make & Engine: A Cobra
What? No pics?
Old 07-02-2006, 01:55 PM
Banned
Cobra Make & Engine: SPF w/392CI stroker
Maybe it's 1/32 scale?!?
Old 07-02-2006, 05:59 PM
oliver350's Avatar
Banned
I was kicked of the gt40 Forum for smart comments..I see i will have no problems here.
OLiver
Old 07-02-2006, 06:21 PM
ENTDOC's Avatar
Cobra Make & Engine: Kirkham 427 (KMP 266); CAV GT40
give us some specifics on the 40,it is beautful. Congratulations. I have a Cav GT40 on the way.
Old 07-02-2006, 06:28 PM
FUNFER2's Avatar
Cobra Make & Engine: 1966 Lone Star 427SC.
Oliver & you lucky basterds that have a GT40..........I'm drooling !
Great looking car, any more detailed pics & info ?
Kev
Kevin
Old 07-02-2006, 06:46 PM
ZOERA-SC7XX's Avatar
Cobra Make & Engine: ERA 427 SC s/n 718, 428 FE
At least you weren't kicked off for dumb comments!
Nice car. Congrats.
Old 07-02-2006, 08:22 PM
FUNFER2's Avatar
dumb comments ?
Kevin
Old 07-03-2006, 06:55 AM
JCoop's Avatar
Cobra Make & Engine: Superformance, FRP460 Big Block
Talking
Congratulations Oliver!
Now how about some specs and your impressions?
Is that fuel injection I see?
Godspeed...or maybe Goodspeed
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 07-03-2006, 10:48 AM
rlearp's Avatar
Cobra Make & Engine: RCR Lola Spider
Good luck with the car, I'm sure she is a pretty one!
http://www.gt40s.com
Old 07-06-2006, 09:44 AM
oliver350's Avatar
Banned
Default 1st hundred miles!!!!!!
Well took her out for the first hundred miles...All I can say is "HOLLY SHI#$$$" !!!
Put the AC on hit the on ramp at 40mph in 1st. gear 80mph in 2nd.
It drives amazingly well with a high degree of comfort and endless speed . The power to weight ratio scary...scary.. scary neck snapping experience. I recommend that if you get a chance to ride in one of these road rockets to do it...It will take your breath away and take you places you never have gone before. I Caution you to try and resist getting your own Gt40. OHH! IF don't like attention, this is not the car for you.
My wife mentioned that I have some how became very atractive to other women with all the looks..I keep telling here it the car honey! Really!!!
Regards OLIVER
Rf Turnkey
Engine 331 dart alum.
Custom Crossram EFI 42 LBS. injectors.
ZF Transaxle
530BPH
Old 07-06-2006, 11:02 AM
Johan's Avatar
Oliver, did you go to Sebring this year ? Nice car (the GT40) !
Old 07-23-2006, 10:12 PM
Bill D's Avatar
Cobra Make & Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Hi Oliver. Glad you got your GT40. Miss your biting humor over at GT40s.com. Cheers
Bill D
Old 09-22-2006, 01:05 AM
AUTOFANATIC's Avatar
Cobra Make & Engine: BACKDRAFT (302) engine
Lightbulb CONGRATS ON THE RF GT40...//Check mine out!!
I have a CAV for sale BUT, I'm also looking for a CAV/RF with the ZF transmission!! Here are pics below & Info. below.
Specifications
Chassis
- Monocoque, TIG welded high-grade stainless steel, integral roll over and side impact protection, tubular sub frames for radiator and transmission.
Suspension
- Independent unequal length wishbones offset A frame, anti-roll bar, aluminum upright (front). Independent double trailing links, lower inverted A frame and upper transverse link wishbones, anti-roll bar, aluminum upright (rear). Built in anti-drive, anti-squat, near zero bump steer.
Springs/Dampers
- Competition coil over gas shocks with adjustable damping rate and variable spring height.
Brakes
- Dual circuit, front rear split with servo assistance, tandem master cylinder, i
proportioning valve. 11.375" ventilated rotors (front). 11.375" ventilated rotors with
separate handbrake caliper (rear).
Steering
- rack and pinion. 3.2 turn from lock to lock.Wheels - BRM style alloy pin drive replica with center knock off 8'T"15" front 10" x 15" rear.
Fuel tanks
(2) - 10 gallon fuel safety cells sill mounted. Original style filler caps, total capacity 20 U.S. gallons. Individual electric pumps and filters with dash change over switch.
Exhaust
- stainless steel original pattern "Bundle of Snakes" eight-branch header system with two collectors, muffler and stainless steel heat shield.
Transmission
- aluminum bell housing 5 speed Getrag transaxle with a 5 button 9" clutch and Race specifications drive shafts with CV joints.
Cooling
- high efficiency, six-core front mounted aluminum radiator with twin auxiliary electric fans. Thermostatic controlled manual override.
Body
- (high strength fiberglass composite construction.) Style: Two door GT, Length: 164.5". Width: 70" Height: 40.5." Wheelbase: 95" Dry Weight: 2,350 Ibs (including 302/Getrag), weight distribution 44F 56R. Ground Clearance: 5" (in road trim)
Interior
- Carpet automotive quality, Leather Dash-board, and doors, Leather seats are adjustable fore/aft, with brass/aluminum vent grommets, pedal box adjustable for tall drivers.
Electrical
- original style gauges (VDO/Smiths) and switches all circuits fused and relayed. Cibie headlamps, all other lights original pattern. Rear mounted battery box with master isolator switch. With top of the line MSD egnition
Malcolm Motor Sports
Engine Specifications
Engine block; 1980s 302 302, 331, 347 cubic inches
Heads; Ford racing heads "X-heads" Gt-40 1.94" intake 1.54" exhaust
Valves; premium stainless steel
Camshaft; hydraulic roller cam M-6250 f303, or z303 for fair to good idling
Rocker arms; Roller Arms -6564 a50-1.7, b351-1.6, or e351-1.72
Lifters; .874 Solid Lifters or roller lifters
Crankshaft; cast or forged to exceed FRPP requirements
Push rod;
Piston Rods;
Pistons; Forged with molly rings
Water pump v-belt pump
Distributor Mallory Aluminum Billet MSD
Intake man. Polished Aluminum Victor Jr. Edelbrock Air Gap Manifold
Carburation Road Demon
Valve covers Aluminum Ford Racing 3.75"
Oil pan stock Ford Racing
Note; Distributor gears match cam material and use proper gear heights.
ENGINE SPECFICATIONS
302 XB3M 395 HP
. MARCH PULLYS
. FORD RACING
__________________________________________________ __________________________________________________ __________
ENGINE 302 XB3M FROM FORD RACING
9.0 TO 1 COMPRESSION RATIO
X HEADS M-6049-X303
HYDRAULIC ROLLER CAM M-6250-B303 M-6007-XB3
INTAKE 1.94"
EXHAUST 1.54"
@ 4000 RPM VALVE LIFT IS .480
ON BOTH INTAKE AND EXHAUST
DURATION AT .050" IS 224 DEGREES
Delivering the BEST machine possible
Old 09-22-2006, 03:32 AM
rlearp's Avatar
Spamming it over here too huh?
Old 09-22-2006, 05:35 AM
computerworks's Avatar
Cobra Make & Engine: Kirkham, KMP178 / '66 GT350H, 4-speed
Rightly so....
Please list cars for sale on their own thread...one per car... in the For Sale forum.
thanks
ron
ClubCobra Moderator
Closed Thread
