Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
Old 07-23-2006, 09:07 PM
Bill D's Avatar
Cobra Make & Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Default Newbie Here - Saying Hello
Hello everyone! I just joined and wanted to introduce myself and tell you what I'm building.
My car is a Race Car Replicas (RCR) GT40 MkI Gulf car. It has an aluminum monocoque chassis and RHD/RHS.
Here are some of the details
331 SBF with KB pistons (10.:1), forged rods and crank
Victor Jr aluminum heads (2.05/1.60 valves)
Comp Cams hydraulic roller cam (.598/.598 lift, 236/236 dur @ .050 lift)
Crane electronic ignition
Holman-Moody aluminum valve covers
ERA bundle of snakes
48 IDA Webers (soon to be ordered)
Armando's GT40 oil pan (polished)
ZF 5-spd
Fidanza aluminum flywheel
15x8 and 15x14 BRM wheels
AP Racing 4-piston calipers
11.75" straight vane ventilated rotors
AVON historic tread tires
Original style seats
LUKE FIA 6-point racing harness
Here are some pictures of my build so far...
Adjustable spoiler recently fabricated similar to the one on 1076P
Test fitting the wheels after they were painted
Bill D
Old 07-23-2006, 09:10 PM
Bill D's Avatar
Some pictures of the engine. Still need the Webers, but the wallet is empty right now.
Bill D
Old 07-23-2006, 09:44 PM
Cobra Make & Engine: Butler Racing/427 side oiler
WELL I think it looks VERY VERY cool ..cant wait to see it finished
Old 07-24-2006, 06:57 AM
oliver350's Avatar
Banned
Lookin GREAT bill!! Ron Is going to be Very upset that you strayed from his
beloved Gt40 forum! Your going to get a spanking. Your another one of his kids skipping school. Like me I wouldn't listen to him so he kicked me out of the house Yor are getting close to getting her done. You are going to love it as I explained in the email i sent you.
Best regards OLIVER THE GREAT
Old 07-25-2006, 04:59 PM
Jamo's Avatar
Super Moderator
I contributed to CC in 2006
I have in the past contributed to CC
Cobra Make & Engine: KMP 184/482ci Shelby
Had I seen this before your latest rant...you would be gone.
Stop...now.
Jamo
Old 07-26-2006, 04:53 AM
albanycobra's Avatar
Cobra Make & Engine: Pace Alumina 427 #69
Hi Bill
I've been following your build on GT40s.com .
Your workmanship is awesome and your car will be the envy
of most when it is finished. I bought a DRB kit but I wish I
bought an RCR, that mono alloy tub is excellent.
Old 07-26-2006, 04:58 AM
JCoop's Avatar
Cobra Make & Engine: Superformance, FRP460 Big Block
Thumbs up
Bill, it looks gorgeous!
I envy your optimism with the straight pipes. Not even a slip fitting for a muffled switcheroo for inspection? I wish I could be there for when you first fire her up with the Webers. Even with my mufflers, my set of 48IDAs howl soooo sweeet! Bet you can't wait.
BTW, check out the cheap (relative term of course) route I took, Weber USA's kit for $1795, then send them to Ian in CAV Canada for about another grand or so for vacuum, plumbing and turkey pan set up.
PS, any way I can get a copy of the drawings or sheet on the adjustable spoiler? Beautifully done...
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 07-26-2006, 06:15 AM
Bill D's Avatar
Wink
Thanks for the compliments JC. The dimensions for the spoiler will be different for each car manufacturer since no two bodies are the same shape. What I did was tape some poster board against the rear of the car, trace the body shape with a marker, then raise the poster board two inches, and then recontour the outside edges to blend in. Took a few tries before I got the shape where I wanted it.
Once I was happy with the look and shape, I placed the poster board on 3/4" particle board. I used a jig saw to cut the shape, then sanded and sanded and sanded some more until the edges were smooth (no ripples).
I clamped a piece of .080 6061 T-6 aluminum sheet to the jig and used a router with a flush cutting bit attached. Makes a zillion hot little aluminum shavings. After removing the now cut-to-shape spoiler from the jig, I used a metal file to clean up the edges of the aluminum, followed by 150 grit sandpaper on a block to make the edges nice and smooth.
I had a machinist mill the slots. They are 3/8" by 1.5" long. I used some 5/16-18 x 1" SSTL hex drive button head screws in the adjustment slots and 1/4-20 SSTL hex drive button head screws in the middle. NOTE: The two middle screws are fixed and because of the restricted area they go in, I drilled the holes in the fiberglass undersize and use the threads of the screw to cut into the fiberglass.
Hope this helps
