Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
Old 06-24-2008, 05:55 AM
Cobra Make & Engine: 2001 SPF, Sold =(
Default Twin Front Nostril VS Single
Is there any advantage/disadvantage to either?
Old 06-24-2008, 09:51 AM
mikiec's Avatar
I have in the past contributed to CC
Cobra Make & Engine: FFR 302 carb
I have no idea. I do like the look of the twin over the single.
Old 06-24-2008, 01:58 PM
Jim Holden's Avatar
Cobra Make & Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
The only diifference might be that the wide open "nostril" will be less restrictive to air going through the radiator. Too, there is a vent at the base of the windshield that feeds air to the cockpit. If you have the wide single nostril, hot air from the radiator flows up and in to the vent. Whereas, the twin nostril setup (in theory) directs air to either side and cooler air gets to the vent. That may be why the MKIIs deleted the cockpit vent, because they too had a single (albeit slightly different shaped) nostril.
Old 06-24-2008, 06:39 PM
JCoop's Avatar
Cobra Make & Engine: Superformance, FRP460 Big Block
Aside from a probable aerodynamic advantage due to the smoother airflow over the windshield,
it definitely passes more air through a larger radiator for much better cooling.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 06-25-2008, 12:18 AM
WOW... that is a beautiful GT40, JCoop.
Old 06-25-2008, 07:08 AM
PatBuckley's Avatar
Cobra Make & Engine: CAV GT40 with 331 KC
...or perhaps that center section acts like a venturi and causes much more air to flow through which makes for way better cooling?
Seems that most cars used the twin opening set-up and I am sure if the single opening one was better that wouldn't be the case?
edit: The radiators are the same size.
Old 06-25-2008, 07:14 AM
Jim Holden's Avatar
Just an observation: The twin nostrils were on the early cars. The late JW cars (see 1075) had the single wide open nostril. Hard to beleive that they would have gone "backwards" if the twin nostril setup was more efficient.
Old 06-27-2008, 07:46 PM
mreid's Avatar
Cobra Make & Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
I also like the look of the twin better. Here's mine:
Fact is that at speed the twin causes the nose to lift.
Old 06-27-2008, 08:58 PM
GlynMeek's Avatar
Cobra Make & Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
hmmm...on a more modern note, Porsche just went to 'twin' side intakes on the new 997 Turbo, as opposed to the single side intakes on the 996 Turbo! Interesting question!
Surely their is a 'fluid dynamics' expert out there who can answer this 'flow' issue!!!!!
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
Old 06-27-2008, 09:16 PM
BT SNAKE's Avatar
Cobra Make & Engine: Midstates Cobra, RFGT40
Thumbs up
I don't believe any of us that own a GT40 Replica will ever drive one fast enough to find out which is more effective.
You should pick the one you like or buy both and switch off once in awhile. I personally have the twin nostril and never an overheating problem in 7yrs.
Hersh
Old 06-27-2008, 09:23 PM
Jac Mac's Avatar
Cobra Make & Engine: DIY Coupe, F/T ,MkIV.
Smile
The large single outlet gives wayward pedestrians somewhere warm to recover while they await the ambulance!
Jac Mac
Old 06-27-2008, 09:31 PM
BT SNAKE's Avatar
Talking
Hersh
Old 06-28-2008, 12:46 AM
The front panel that houses the nostril seems to be removable. How difficult would it be to switch from one to the other? I know matching the paint would be an issue.
Old 06-28-2008, 01:02 AM
Jac Mac's Avatar
Smile
As long as it has the same curvature & dimensions, yes the panels can be interchanged, problem is not all body/kit manufacturers use exactly the same dimensions for this part. Many make both versions available & therefore if you have a CAV, RCR etc you will have a choice, but dont necessarily expect the RCR to fit the CAV or vice versa.---- not picking on these two makes, just using them as examples--- add to this I have observed detail changes that mean there may be three or four versions of both single & dual types, stuff like bumps to clear the spare tyre when it was fitted to some early cars along with very deep versions like the one on J Coops car above. My own set of mold patterns has a shallower single nostril version that is only about 6" deep. I think Jay Cushman has several versions of both variants as well.
Jac Mac
Old 06-28-2008, 02:46 AM
So... assuming you had a CAV GT40, and you purchased the different panel from CAV, it would probably be a fairly easy swap.
Old 06-28-2008, 03:06 AM
Jac Mac's Avatar
Smile
I think that would be the case, but check with them (CAV) direct to confirm it. There is a Zip File with manufacturers & agents contact details further down the page on the -GT40 Talk- forum . Sorry Im a computer dummy & dont have the necessary magic wand to transfer details like that from one place to another!
Jac Mac
Old 06-28-2008, 05:50 AM
ENTDOC's Avatar
Cobra Make & Engine: Kirkham 427 (KMP 266); CAV GT40
2 minutes tops
Old 06-28-2008, 07:27 AM
Originally Posted by ENTDOC View Post
2 minutes tops
That is what I was hoping to hear. I'm actaully looking at CAV which is very similar to the one in your avatar.
Old 06-28-2008, 09:31 AM
PatBuckley's Avatar
Or you could find someone who has the twin nostril cover in the same color and trade him.
Tell him all about how much cooler the car runs with the single opening.
Old 08-23-2008, 09:26 PM
Cobra Make & Engine: investigating for choice
Default Twin vs single nostril
Not that it responds to the original question, but I think that the original twin nostrils resulted from the spare tire required by FIA when the original GT was designed. The tire was layed flat under the front bodywork and the two outlets exhausted the radiator air from around it. Early plastic models of the original car in the '60's demonstrated this. (shows how old I am)
The nostril shapes changed and were ducted as the car was developed and were finally changed to the single nostril for better cooling when either the tire was moved to a more vertical orientation or removed entirely from the front when allowed by a rule change (I don't know which).
Thought this might be interesting.
