| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
02-06-2010, 08:16 AM
KS
Cobra Make, Engine: jbl
justus, pro systems, barry grant pictures
so it's slow, and here a few pictures of the three carbs for comparison, hard to tell from the pics and jet size is not included, but i'll include a few observations.
in the order above, in the pic 2nd from the left the justus plate has the two holes lower in the plate, 3 spread emulsion bleeds, 2 with inserts, the pro systems has 3 e bleeds closer together with inserts, the bg has 5 e bleeds with inserts, bg block has threaded inserts and not all holes are used, pic on left of bg plate has extensions i added.
02-06-2010, 08:19 AM
KS
few more pics
justus carb on left has boosters epoxied with what appears to be modification to the inner diameter radius, i imagine the boosters were aligned then epoxied, throttle bores on justus carb have cnc'd diameter and an additional hole next to the idle bleed for what i'm not sure.
02-06-2010, 08:22 AM
KS
additional pics
bottom of the bg carb, and all three carbs together.
looks like they all have plenty of adjustability and differences such as emulsion location and sizing. the justus carb has holes drilled in all the butterflies, the pro systems has holes drilled in the butterflies on the primary side only, the bg has no butterflies holes drilled. the justus carb is square jetted with pv caps on both blocks, i'm surprised there were no jet extensions. the pro systems carb was jetted different front to back with pv in front, bg was again square jetted with pv front and back. the bg is the rr 850 version, the pro systems was ordered for the jbl, the justus was bought used and presumeably for a "sporty" vehicle, not sure.
02-06-2010, 08:49 AM
KS
almost forgot, here is what efi looks like
02-08-2010, 07:51 AM
CC Member / Sponsor
UT
Thanks for the pictures.
02-08-2010, 09:25 AM
ont
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Re post#3
The Pro Systems carb appears to have the holes drilled in the secondary's only---just like mine.
See photo in post #2 W/red billet baseplate.
Craig
02-09-2010, 06:51 PM
TN
Originally Posted by vector1
additional pics
Just to clarify --
The "caps" you're referring to aren't a means of eliminating the power valves; they are baffles which keep the power valve's fuel entry ports from becoming uncovered during hard cornering. In the case of the carb in question, the PVCR's in both metering blocks are .063" in diameter, which equates to roughly nine jet #'s worth of fuel metered inlet area -- quite a bit to lose...even momentarily...when the PV's start sucking air.
Jet extensions on a road car are almost never needed if fuel control issues in the float bowl are properly addressed. More to the point however, they often cause problems (engine stalling) of their own upon hard braking. For years, the "catch 22" was that if your engine made enough power...and your chassis and tires could hook that power to the ground...and your driver didn't run low on talent, then a car that truly benefited from jet extensions under acceleration would suffer a like amount from them on braking. The true solution to the problem -- metering blocks with lowered jet locations and float bowls designed with a "sump" to accommodate them -- didn't come around until just a few years ago.
02-09-2010, 10:17 PM
Ca
Remember when Barry Grant used to modify Holleys before he formed the Demon Carb product line.
[IMG]  [/IMG]
Rick
02-10-2010, 04:41 AM
Stolen Avitar
GA
Re. the BG not having drilled throttle plates; remember that the BG has the center air bleed in the base plate between all the venturies (can't remember what it's called right now. Hey, it's early!) which obviates the need for the drilled plates.
02-10-2010, 10:14 AM
Cobra Make, Engine: SPF GT40
Originally Posted by StanJ
Just to clarify --
Interesting comment about the jet extensions. My Quick Fuel carb has them, but only on the secondaries. Presumably on braking the secondaries are closed so lack of gas doesn't hurt? I'll be interested to see on track days if the primaries go dry under sustained braking.
02-11-2010, 12:23 PM
QLD
Barry Grant modified Holleys didn't have "idle-eze" until he released his Demon carbs.
Jet extensions are only necessary on the secondaries since g force under hard acceleration may uncover the secondary main jets.
Can never be a problem on the primary since the primary main circuit under heavy neg g force (braking) is not operating.
Gary
02-11-2010, 01:15 PM
Stolen Avitar
GA
Of course you're right Gary but the OP's first set of pics included a BG Demon and that's why I mentioned the idle-ez:
Steve
02-11-2010, 02:59 PM
KS
Steve
neither this carb or the bg 750 like it that i have in my possession have the idle-eze.
02-11-2010, 05:33 PM
Stolen Avitar
GA
Dang man, that's what I get for thinking. Mine has it and I just made the leap that they all did. It's a great idea though.
Steve
04-04-2010, 07:02 AM
Cobra Make, Engine: Unique
butterflies
What size are the holes in the butterflies and why are they there?
04-04-2010, 11:00 AM
Ne.
vector 1- Have you used the BG FI ?
Regards,
Kevin
04-04-2010, 12:46 PM
KS
not sure what size, they vary according to what the engine needs. instead of opening the butterflies to raise the idle which uncovers the transition slots, holes are drilled in the butterflies to allow enough air through the carb.
04-04-2010, 12:49 PM
KS
not sure what the bg fi stands for. looks like barry grant fuel injection.
04-05-2010, 06:19 AM
Ok
I'll bite again, why would you need to drill holes in the first place and what would the symptoms be if someone needed to do this.
04-15-2010, 09:47 PM
QLD
If your engine now idles at 800rpm with 5 inches of vacuum instead of 800rpm at 16 inches of vacuum (after a cam change), it is consuming more air.
Opening the butterflies to compensate exposes the transfer slots and makes the mixture screws less responsive to uncontrollable.
It also shortens the idle/transition phase of the engine and produces off-idle flatspots etc.
Drilling holes in the butterflies allows the extra air, but you need to drill in small increments to sneak up on the optimum.
The transfer slots should have about .020 exposed when looking from underneath.
Gary
