Old 11-05-2010, 11:47 AM
Default Holley Carburetor Instalation And Tuning DVD
I was directed to a online video about tuning Holleys. www.BoxWrench.net. Good video but it kept locking up and or freezing. I found the DVD "Holley Carburetor Installation And Tuning". It is available through several sites. I thought I found a deal at a local parts store. Apparently the DVDs come with most new Holley carbs. The store had one DVD that had been left by a customer. It breaks up and so one almost like the online video. Are the new Holley DVDs available on Amazon ans so on the same?
Mike H
Old 11-05-2010, 12:11 PM
Tom Wells's Avatar
Michael C Henry,
Are you sure those aren't Lucas DVDS?
Tom
(sorry - couldn't resist)
Old 11-05-2010, 12:18 PM
That was pretty funny. All of the Holley vids are available on HolleyTV, which is here: http://www.holleytv.com/featured_landing.php?reset=true
Old 11-05-2010, 12:21 PM
I got one of those CD's with a new Holley. I can't get it to play on any of my three computers. It won't even recognize it AS a disc of any kind.
...gotta be a Lucas disc.
Old 11-05-2010, 12:51 PM
I was viewing the vacume throttle one, that went much better. Did anyone like the paper clip method?
Mike H
Old 11-05-2010, 01:50 PM
I've tried it, but I can't seem to get the paperclip to stay on correctly. I don't know if it falls off or slid down or what. So, it's kind of iffy from my stand point (dual carbs here).
Old 11-05-2010, 02:40 PM
I have successfully used a zip tie instead of the paperclip. Zip it up lightly snug, then cut it off when done. I've had paperclips entirely disappear on a test run and that gets pretty irritating.
Old 11-05-2010, 03:35 PM
The zip tie sounds like the best idea yet. Seting the tesion could be tricky. May want to leave a short leg sticking out. What size of zip tie did you. Curently I have the programable rev limiter set at 6,000 RPM, doesn't seem to be opening. I'll need to take the car somewhere where I can open it up. maybe next summer.
Mike H
Old 11-05-2010, 03:38 PM
The shortest and lightest one. They are probaby less than six inches in length and are light enough to make a tight circle. They are not the big strong ones -- you might be able to bust these apart with your hands... maybe.
Old 11-05-2010, 06:18 PM
Thats a good tip Patrick. I got some real small ones AND I think a little WD-40 in just the right place will help as well. So they slide smoothly.
Old 11-06-2010, 10:24 AM
dcdoug's Avatar
You can also use a twist tie. They work well too.
www.partskeeper.com
Old 12-18-2010, 06:17 AM
Cobra Make, Engine: Unique
Default vacum hose
I have taken a piece of vacum hose about 1/4 inch long with a slit cut in it. I slip it on the secondary control like yawl are using the zip tie and twist tie. It worked well and doesn't come off, hard to overtighten it too.
