Go Back   Club Cobra > Engine Building, Tuning, and Induction > Holley Tuning
December 2025
Old 06-11-2011, 11:54 AM
Chaplain's Avatar
Cobra Make, Engine: Everett-Morrison, 429CI
Default Carb Noise
The carb I'm using is a Holley. When i rev the engine the carb makes a screaching noise. It sounds exactly like a belt slipping but I've checked thouroughly and it is definetly the carb. Any thoughts on what it might be?
Thanks
Chaplain
Old 06-11-2011, 01:08 PM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
Perhaps a vacuum leak at the base gasket. Torque the mounting bolts/nuts to 80 to 100 inch pounds using a criss-cross pattern and see if it helps.
Old 06-11-2011, 01:09 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Never heard of that before, I'd double check with an engine scope.
" It ain't no big deal"
Old 06-11-2011, 01:24 PM
Jerry Clayton's Avatar
Worn throttle shaft in base plate----vacume /air leak there---same sound from both sides of carb??
Old 06-11-2011, 01:57 PM
RET_COP's Avatar
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Agreed, [vacuum leak] squirt some wd40 in the areas described above and it should change the sound or stop it for a short time.
Lou
Old 06-11-2011, 02:10 PM
FWB's Avatar
FWB FWB is offline
Thanks
Chaplain
do you have the factory manifold and carb on your 429?
is there an EGR valve behind the carb? if so it may have crapped the bed and causing the screeching sound. which is a vacuum leak.....
fred
Fred B
Old 06-11-2011, 07:12 PM
DanEC's Avatar
I've had an Edelbrock carb make a whistling sound because I used a base plate gasket with a single passage for the bores. Switched to a 4-hole gasket (4-hole intake) and it stopped. Slim chance this is your problem but something to check.
Old 08-04-2012, 09:48 PM
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default whistling/shrieking Holley
On my 67' Corvette, the Holley 1850, after about 10 years, would scream so loud you could hear it on the freeway.
Eventually I took the carb apart and used 220 wet/dry paper to sand the flats on the main body...metering block...float bowls...any surface that was supposed to be flat...
Used a milled steel saw table as the base when possible, moved the piece in figure 8's over the sand paper with a little water.
The carb was quiet for several months...eventually the noise returned, but for a while it was quiet and didn't weep gas from every joint.
So, a vacuum leak, why ?..... something is not sealing...you may be able to sand it flat or have it milled....or if the old pot-metal castings are disintegrating....give it up and get newer parts.
Not your imagination, they can make horrendous noise.
Pete
ERA 289 #2027
Old 08-04-2012, 10:45 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
Mine squeals occasionally like a slipping belt when it is cold and I assumed it was the belt. Doesn't do it when it is warmed up. Since I don't have a choke I have to keep my foot on the gas to keep it running. You think it is a vacuum leak? Engine does not perform like it has a vacuum leak.
Old 08-05-2012, 03:31 AM
Gaz64's Avatar
I've seen some carbs with a squealing noise from airflow going past the butterflies at idle.
Gary
