Old 11-26-2011, 05:48 PM
DanEC's Avatar
Default Choke for dual quad FE
This is a follow-up on my earlier post about dual quads on my FE. I would like to have a functioning choke system on the motor since all I need is a manual choke cable. Not having multiple carbs on any of my cars before I'm not sure if I need to only hook up the front carb, or hook up both carbs. I'm pretty sure all the old 3 x 2 setups on Pontiacs, Chevrolets, and Mopars only choked the center carb - but I don't thing the outer carbs had idle circuits. With the twin 1850 Holley carbs - both have idle circuits that are in operation. The front carb appears to require about 15 deg throttle opening before the back carb starts to open.
I'm thinking I will need to have both choke valves hooked up to have an effective choke and fast idle system. What do you think? (yes - I know I don't need to have a choke sysem but I like having one.)
thanks
Old 11-26-2011, 06:03 PM
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Choke on the first carb is all they used!
Old 11-27-2011, 02:04 AM
Gaz64's Avatar
All dual four barrel intakes only run the choke mechanism on the "primary carb" if they are progressive.
You will find all progressive four barrels have the "primary carb" primary barrels as near as practically possible to the centre of the engine.
The whole engine breathes on this 15% of throttle.
Old 11-27-2011, 03:44 AM
DanEC's Avatar
OK, front carb only - even though both carbs have idle circuits that are in play at idle.
This isn't like a 3 x 2 setup where only the center carb has an idle circuit.
Old 11-27-2011, 03:01 PM
SuperHart's Avatar
Send a message via AIM to SuperHart
As previously said, you only need the choke on the primary carb. The choke assembly and all associated parts can be removed from the secondary carb. Below is a photo of how I set my carbs up, a pair of Holley #8007 390 cfm 4160s. Using the manual choke arm from a Holley choke kit mounted upside down (because the carbs are mounted in reversed position) I secured the choke cable to the secondary carb vacuum pot assembly with the mounting clamp and then mounted the choke cable in the dashboard of the car. It works quite well and was a cinch to rig up. Even though my motor is a 351W the same thing would apply to a FE motor.
Old 11-27-2011, 03:06 PM
DanEC's Avatar
I'll look at that method of reversing the choke lever. That would simplify hookup and routing of the cable.
Old 11-27-2011, 03:16 PM
SuperHart's Avatar
When I say "reversed", what I really meant is that I mounted the lever upside down from the usual position. The lever is not "turned around", just upside down. That way you still set the choke by pulling the cable knob out. I hope that's clear.
Old 11-28-2011, 05:08 AM
DanEC's Avatar
Yes, it was. Right now mine is set up where it will have to be pulled from the front to close the choke.
Old 12-03-2011, 02:29 PM
Jeff Frigo's Avatar
Why would you ever need a choke in Arkansas, are you kidding?
Jeff
Mark Donahue
Old 12-03-2011, 05:56 PM
DanEC's Avatar
With your being from Chicago I can see your point. I just like my engines to start once from cold and keep running versus several start/stall/restart cycles that washs the cylinder walls down with gas. And it's a tuning challenge to a choke/fast idle system set up to where it works properly. But no, I probably won't be venturing out in many sub-40 deg days.
Old 12-03-2011, 06:34 PM
If anything a choke will exacerbate this because it intentionally creates a rich condition by blocking the primary airflow. If you have your carbs setup right, you should be able to start a 2x4 setup without a choke on the first couple of revolutions and get it up to 1300-1500 instantly and keep it there. I push the pedal to the floor twice, keeping it to the floor the second time and crank it. It fires instantly and doesn't struggle to run.
Old 12-03-2011, 06:47 PM
X 2. That's how it works.
Chas.
Old 02-20-2012, 01:41 PM
I tried to clean my emmissions up. My cruise hyco were almost with in limits but idle was allmost 11 times the limit. I had new metering plates prepaired for me. That cleaned up the idle. The garage was not as gassy at startup anylonger. Colder weather ( anything less than a warm summer day) starting was now a problem. I needed to put the choke system back . I had the choke towers cut off both carbs but had kept the fast idle cam that is used with a choke for warm up. So I had to get another carb main body with complete choke tower and put all my parts on that carb body.
Mike H
Last edited by Michael C Henry; 02-20-2012 at 01:57 PM.. Reason: I needed to add stuff
Old 02-20-2012, 02:39 PM
xlr8tr's Avatar
Cobra Make, Engine: CAN-AM cobra, 460 SVO
My 2 X 4 setup starts fine, almost exactly the same process as you use when its warm outside (65+ degrees) but its a bastard when its colder than that...
Mark
Old 02-20-2012, 03:15 PM
flaflier's Avatar
Cobra Make, Engine: ERA154 427 HR
Pump it twice, turn the key, and she fires to life. Feather the throttle keeping it about 1300-1500 for 30sec to 1 min, then let her go.. of course I live in Central Florida, and it's mid 70's or warmer 98% of the time!
