Like Tree1Likes
  • 1 Post By Rick Parker
Old 09-08-2014, 06:27 PM
Default Drop Base for Holley 4150
I`ve been fighting poor fuel distribution and a carb that just wouldn`t respond to changes like it should for quite a while .
Because of very limited underhood clearance , I couldn`t put just any filter setup on it and the spun aluminum ones were all that would fit . However , the problems with them were insufficient vent tube clearance and a very steep wall behind the element that made the air do some really horrible turns which created a lot of turbulence and other undesirable things ... all of which affected carb tuning badly .
I was talking to a carb man who is one of the best in the country and he said try the Chevy L88 air filter base . Seems he had done a lot of testing and found it to be about the best out there . I did and found that those guys really did know what they were doing back in the `60`s . That base is one of the most efficient units out there , has more drop than the spun aluminum units , correct flow paths ( no steep walls ) and required minimal rework to fit the 4150 .
Basically , just cut off the PCV tube on the bottom and plug it ( hits the accelerator pump arm ) and open up two slots . Clears all linkage and fuel lines and allows me to run a full 3" tall element and have about 3/4" to 1" vent tube clearance to the filter lid .
Carb responds to jet changes the way it should , seat of the pants power is better in all rpm ranges and fuel distribution is where it should be . Car is much smoother at low rpm ( 2200 to 2400 ) also .
All this for about $69 !!
If anyone is interested , I can put up a few before and after photos .
Old 09-08-2014, 06:48 PM
Rick Parker's Avatar
One of the best improvments is to utilize their (or Pro forms) HP main body, with the nice radiused paths into the venturis and made without a choke housing. That alone is one of the best improvements for a Holley. Attempting to utilize a Holley with a functioning choke with a low profile air filter is a futile exercise.
joyridin' likes this.
Old 09-08-2014, 07:02 PM
Rick ... I agree , but this carb is a Pro Systems HP950 with all the bells and whistles , and no choke or choke tower . Also , everything is radiused into the venturies etc . Still had problems and once I got the proper air flow path and vent tube clearances , everything started working . Even with what Pro Systems did , tuning with the spun aluminum base was an exercise in futility .
Old 09-09-2014, 05:55 AM
Seagull81's Avatar
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
How about some pictures and part numbers?
Steve
Texas Cobra Club-Seguin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
Old 09-09-2014, 07:41 AM
Cobra Make, Engine: BDR, 302
Nick A. sells a nice drop base package that includes K&N filters. Great package for turkey pans and clearance issues.
Old 09-09-2014, 10:36 AM
Cobra Make, Engine: UCC 427GT, 461
Where did you get the air cleaner from and what filter did you use?
