Old 06-08-2013, 07:09 AM
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
Default Ignition
Should my ignition box have power even though the key isn't even in the car? The reason I ask this is because my battery goes dead after is sits over night. Found out the ignition box is getting power all the time.
Old 06-08-2013, 08:16 AM
MOTORHEAD's Avatar
Don't know what box you have, but an MSD 6al has 2 power inputs, one from the ignition ckt, and one direct from batt. Could be component failure in box. Disconnect batt cables, measure resistance from positive cable to ground. should be "open", infinite res. If not, disconnect box main power wire (should be fused, remove fuse) and ck again. If res is now infinite, you've identified the culprit !
"When Injustice becomes Law,
Old 06-08-2013, 08:26 AM
lovehamr's Avatar
Stolen Avitar
Or it could be something other than the ignition box..............
Steve
Old 06-08-2013, 08:28 AM
It is a Pertronix Second strike, and thanks I will check that out.
Old 06-08-2013, 09:18 AM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
Second Strike installation instructions from the Pertronix site:
http://www.pertronix.com/support/man..._strike%20.pdf
Old 06-08-2013, 09:34 AM
thanks bingo2. good info!!!
Old 06-08-2013, 11:20 AM
MOTORHEAD's Avatar
I see the pertronix A+ is wired hot to the batt also. Maybe something else, but anything wired direct to the batt is the most "likely suspect" !
