Like Tree1Likes
  • 1 Post By my427cobra
Old 10-04-2018, 04:50 PM
fastd's Avatar
Default Ford Regulator Replacement
Anyone know the replacement number for Ford Regulator part numbers D4TZ-10316 A or D9PZ-10316 A.
And anyone how to decode these numbers?
I see C5AF-10316 A on amazon that is rated 38/42 amps...I can't find the ones above and don't know what they are rated.
Thanks in advance.
Old 10-04-2018, 07:34 PM
Senile Club Cobra Member
10316 is the Ford "basic" part number, all alternator regulators are 10316, the prefix and suffix indicate the application.
The C5AF you reference will work fine as likely your Cobra doesn't have AC, a power top, etc. Most any aftermarket regulator will do the job unless you are looking for a reproduction unit to replicate the units used in 60's Cobras. All of the current aftermarket units have "low" covers and are electronic, the O.E. units have "tall" covers and are electro-mechanical type.
Here is new: https://www.summitracing.com/parts/s...caAk9IEALw_wcB
And here is original type: https://www.google.com/imgres?imgurl...act=mrc&uact=8
rick@autoventureusa.net
Old 10-04-2018, 08:28 PM
fastd's Avatar
great; thank you.
dumb question: if I have a mechanical voltage regulator now, what does it take to convert over to an electronic one? (I did a google search but didn't see specific answer).
Old 10-05-2018, 03:58 AM
Originally Posted by fastd View Post
great; thank you.
Nothing, just replace the electro-mechanical unit with the electronic. There is nothing required to substitute.
Old 10-05-2018, 07:03 AM
fastd's Avatar
great; thank you.
Old 10-05-2018, 07:26 AM
Cobra Make, Engine: NAF 427
Or. you can get the electronic version (which has the top riveted on), drill out the rivets, and replace the low top with the older high top using screws to fasten the high top to the electronic regulator base.
New electronics dressed like the old electro mechanical.
Just a thought.
Greg
dcdoug likes this.
Old 10-05-2018, 10:46 AM
Electronic regulator dressed as a 60's period correct electro-mechanical regulator:
Old 10-05-2018, 11:08 AM
Cover is upside down, the plug should be at the bottom of the cover with the text readable. I would guess that with the wiring in your car, you installed the cover to be "readable" from the normal hood open position but correctly it would be opposite!
And what you suggest is what I did in the 80's and 90's as a Ford Restoration Parts license holder! We took electronic units that we special ordered with the "tall" cover and stamped them to the various engineering numbers used on 60's Fords.
Old 10-05-2018, 11:53 AM
Hi Mark IV. Yup , you are absolutely right.
I just like it better that way!
But you may have noticed I lettered the wiring terminals.
Greg
