Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > JBL-- JBL Larry G.
Old 11-09-2008, 03:54 AM
Cobra Make, Engine: jbl
Default rear dif oil for your rearend
hello richard
we're talking mechanical stuff here.
i put about a quart of some diff fluid in the rear of this car after i got it since it was low and after reading another post about not using synthetic thought i had better check since i had some laying around that i used.
what type of oil is recommended, does it matter synthetic or mineral?
it has the 3.73 rear with al pumpkin and i think dave said it is a jbl rear. guess if i knew what type limited slip was used i could figure it out if there is more than one.
thanks
Old 11-09-2008, 05:11 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
The whole problem with transmissions and differentials is that almost all of them have some type of clutch (synchronizer) or another. Thus the need for a fluid that is not too slippery yet provides the necessary lubrication. Whether it is synthetic or not is probably not the issue.
If possible, find out what the manufacturer recommends and go with it.
Bob
Old 11-09-2008, 05:38 AM
thanks bob, i don't know what kind of ls is in there, that is why i'm asking jbl since they put it together.
Old 11-09-2008, 08:54 AM
427 S/O's Avatar
Ford sells 'friction modifier' for the LS rear ends, I put a bottle in my jag., works!.
Perry
Old 11-10-2008, 06:05 PM
Richard Hudgins's Avatar
Cobra Make, Engine: Porsche 928 S4
Vector 1,
I am pretty sure that your car has the Ford Traction lock unit. You can use Red Line synthetic shock proof gear oil 75w90 (has friction modifier), or AMSOIL Series 2000 75w90. If you use a standard rear gear lube you will have to put in the Ford friction modifer additive.
I would call Red LIne or Amsoil for their recommendation just to make sure you have the right product for the unit.
Best regards,
Richard Hudgins
Old 11-10-2008, 06:26 PM
thanks richard
Old 11-13-2008, 09:25 AM
Cobra Make, Engine: Look-a-like cobra POS
I have used Royal Purple Syn with good results. I may have to add a little Friction Mod. - it cogs slightly when making turns. (Shelby/Dana 44 Ltd slip)
B. Ewing
Old 11-13-2008, 09:27 AM
BTW - You may not have to add the entire bottle depending on the fluid.
B. Ewing
