Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
Old 06-20-2007, 07:37 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Default Shift point
Just received my dyno results on my Keith Craft engine. 622HP and 630 TQ.
My question is, what should the shift point RPMs be to maximize acceleration? The TQ peaks at 4700 and the HP at 5800.
RPM HP TQ
4700 564 630
4900 577 618
5100 591 608
5300 605 600
5500 615 587
5700 621 572
5900 622 553
6000 619 541
Old 06-20-2007, 07:42 AM
DavidinDurango's Avatar
Question cannot be answered without knowing tranny ratios.
You will want to shift so the rpm in the next higher gear (the gear you are shifting into) is at torque peak.
Sounds like fun, keep the rubber side down.
DavidinDurango
mostly fords, with "some stuff"
Old 06-20-2007, 08:33 AM
Cobra Make, Engine: FFR,Blue and White
Here is the reply to your question from the FFR Forum
posted June 20, 2007 07:56 AM
I posted a link to an Excel spread sheet calculator that I wrote in another thread.
Here is the link again
http://putstuff.putfile.com/84101/4299774
enter your data in the yellow fields. The transmission ratio's that are already there are for the TKO.
Look at the graph that shows torque at the rear wheels you want to shift when the torque is higher in the next gear than the gear you are in.
The graph gives you speed in mph then look at the speed in gears graph to get rpm.
You can stretch any graph to make it easier to read.
You will need to do your own test to see how much rear wheel torque your car can put down through the tires to the pavement by flooring it at different rpms.
steve
Old 06-20-2007, 08:44 AM
danc30's Avatar
Default Thanks
Thanks Steve and David. This helps a lot.
Old 06-20-2007, 10:57 AM
Cobra Make, Engine: Backdraft 302
so, the HP #'s you put in the yellow boxes is at the crank, not rear wheels, right?
-- Ray D
Old 06-26-2007, 07:58 AM
It doesn't matter, use what ever numbers you have.
Steve
