05-27-2008, 03:40 AM
CT
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Vacuum port on QuickFuel
Hi Keith. Thanks for your help the other day on my fluid leak. All fixed. Now I am tuning up, and I noticed that there is an open vacuum port on the carb, to the right of the electric choke as you are looking at it. It's a QuickFuel.
Should this be plugged before I proceed? Since you guys dynoed the motor I presume this either should not be plugged or it doesn't matter, but I thought I would check with you just in case.
If I can see you, I'm too close
