Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
Old 07-05-2008, 05:47 PM
Cobra Make, Engine: keith craft 427, tko600, very shiney pile of parts
Default header size matters?
Hi,
i can get 1 7/8"primarys premade or should i get specially made 2" primarys . As there's not much restriction in the rest of system will it make a difference on my kc 427 sbf as i've been told full length under body pipes make better power anyway?
Old 07-05-2008, 06:10 PM
Cobra Make, Engine: Cutting Edge, Boss 429
tuska,
That is a great question for your engine builder. I am sure he would have an opinion.
Old 07-05-2008, 06:39 PM
jams's Avatar
Cobra Make, Engine: B & B
I have watched a few episodes of Horsepower TV (SPIKE) where they dyno test different products including headers. Size, length, bends and other factors do make a difference. Nothing major from what I remember but definately worth picking the right size, etc. I think you can watch (Buy) episodes from iTunes.
BossCer's comment was good. Match the headers with the engine for the best effect.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 07-05-2008, 09:35 PM
1 7/8" will be fine. The air flow will be more than enough. If you are trying for a world record in some event that nobody cares about then I would suggest that you go for 2".
Old 07-05-2008, 10:18 PM
The 1 7/8 will be fine for what you are doing. You want to make sure they are not blocking the parts at the head opening. The next restriction will be the sidepipe muffler size. I have seen some of these as small as 1 1/2 and that really restricts the Hp as well. Thanks, Keith Craft
Keith C
Old 07-06-2008, 11:29 AM
CHANMADD's Avatar
Primary pipe diameter and length do make a difference.I suggest looking up various dyno runs on similar motors to yours.You will get an idea as to what would be best.The 17/8 sounds big enough to me (thats what I run). The same as intake runner length makes a diffs so does the exhaust dimensions. Bigger is not necessarily better,.....in this case...anyway!
Old 07-06-2008, 12:50 PM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
This is what I have found to be true.
Using the 205 AFR heads, the standard SPF headers blocked part of the exaust ports and hurt hp.
2" SS headers were opened up at the exaust ports and helped hp (45hp) Grinding the blocked part on the 1-7/8" will do the same.
Work on the mufflers.
E
Old 07-07-2008, 06:14 PM
I'll look into mufflers as sugested...literally !! And port match the manifold plates to the head. cheers glen
Old 07-07-2008, 06:39 PM
Cobra Make, Engine: Hi Tech 533
I used these spiral mufflers in my sidepipes and did pick up a little horsepower.
www.spiralturbobaffles.com
Old 07-14-2008, 12:16 AM
Are your spiral baffles similar Db to glass packed side pipes or do they have a tone of their own?
Old 07-14-2008, 08:46 AM
Thumbs up mufflers
check www.classicchambered.com
Old 07-14-2008, 09:08 AM
Cobra Make, Engine: ERA, Ford 428 SCJ
What about no mufflers? Least restrictive. The downsides are your neighbors hate you and your neighbors 3 blocks over hate you.
I took mine out for a test drive before tearing i all down and I'm still grining.
Old 07-30-2008, 08:51 AM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
I used this from speedway looks the same but much cheaper
http://www.speedwaymotors.com/p/1736...xhaust%20auger
Cobrarich
Old 07-30-2008, 12:14 PM
427 S/O's Avatar
Someone told me to come off the block at least three inches before making the first bend, not sure it matters but I did it when I made mine?.
Perry
