Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
February 2026
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 08-25-2008, 08:51 AM
bobcowan's Avatar
Default Lifter Question
In another thread, you mentioned using high rpm hydraulic roller lifters that extended the rpm range to 6,800 or so. Can you give me more information on these?
Old 09-04-2008, 09:33 PM
Default Lifters
We take the Ford racing hydraulic roller lifter and take it apart, then do some work on the parts on the inside to make the lifter rev higher. We see about 500 to 600 higher rpms with these modifications. It runs 100.00 extra to do the work to a set of 120.00 lifters. Thanks, Keith Craft
Keith C
Old 09-07-2008, 07:55 PM
bobcowan's Avatar
I'v never heard of this. I won't be so crass as to ask what mods you make. But I will ask........ how do I order a set?
Old 09-10-2008, 02:18 AM
Default Lifters
Just give us a call at 870-246-7460 to order you a set of these lifters. We modify the internals and use different clips that retain the lifter plunger. We have the parts made to do this with. Thanks, Keith Craft
Keith C
Old 09-10-2008, 05:01 PM
bobcowan's Avatar
Cool! I'll call tomorrow and order these.
Old 02-23-2010, 09:29 AM
ponvire09's Avatar
Cobra Make, Engine: United States
Send a message via ICQ to ponvire09
BUT, remember to change to 7.350 pushrod length because the LS7 lifter is LONGER than the stock lifter......you will need to make up for this difference....
Old 02-23-2010, 11:00 AM
Default Lifters
We do a lifter in house that we modify to get extra rpms out of the engine. They run 240.00 for a complete set. Things like valve weight, spring used, retainers and locks all have a affect on how high the engine will go.
Thanks, Keith
Keith C
Old 02-23-2010, 11:09 AM
bobcowan's Avatar
LS7? You don't ned a differant length push rod, and Keith modifies a Ford lifter.
Thanks, Keith
They work well. I used them all year, and kept the rev limiter at 6,500. I had them out for a cam change this winter. They still look almost new.
