Old 03-18-2010, 08:58 AM
Cobra Make, Engine: Alum 427 S/C with KC FE 482 Shelby
Default Tire pressure for Avonīs
Can anyone help me out with best tire pressure setting for Avonīs on a 427 with 42 gallon tank and FE Alu block?
I undestood that they are quite sensitive towards pressure and resulting perfomance consequences.
245/60/15 front
295/50/15 rear
Would be thankful for your related input!
Carsten
Old 03-18-2010, 12:05 PM
Cobra Make, Engine: SPF #1019
I would start around 25lbs front & rear, and adjust up/down from there by 1 or 2 lbs...
Old 03-18-2010, 12:29 PM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
Carsten, I'am running 19lbs. cold front & rear. even wear all around. I only have a 17 gal tank
Old 03-19-2010, 12:13 AM
Thanks for the replys!
Your answers reconfirm what I was guessing/fearing: Due to individual driverīs preferences, which are a "vital" aspect, as well as different car configurations there is no "general rule" in regard to what is perfect = Wellcome to the real world..........So I guess I will need to fiddle around a bit -
Still your comments have been highly appreciated
Anyone else having suggestions?
regards / Carsten
Old 03-19-2010, 11:14 AM
Cobra Make, Engine: Kirkham #570 w Shelby FE
Best way to tell is by reading the temp across the tire tread after a mile or so. If the center is hot compaired to the edges, lower the pressure. You can also eyeball the tread to see when it goes flat:
Over inflate to say 30psi then lower the pressure in steps till you see the tread edges make contact with the ground, then drop another pound or so. This will get you in the ballpark, temp readings after this.
Also make sure you do this with a half a tank of gas. 42gal of gas is about 285lbs. so your fuel level will have a greater effect on tread wear. (Or what ever level you think the tank sits at on average.)
Old 03-22-2010, 12:19 AM
Ronbo,
thanks a lot for the input - I guess I will exactly follow your instructions!
regards
Carsten
Old 03-25-2010, 12:54 PM
Take a tire marking "grease" pencil
draw a line across each tire treat area that contacts the road
drive a few blocks
see the lines on each tire.
adjust pressures until the line fades evenly acorss the tread area for each tire
or follow what the manufacturer says for radial tires
Old 03-25-2010, 11:42 PM
Pusherfans, great hint - I guess a combination out of all the above will lead to a good result!
Thanks
Carsten
