01-10-2012, 02:38 PM
AL
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Iron Man Movie Kirkham Build Thread without posts
01-10-2012, 02:44 PM
AL
October 2010
-Replacing the reject suspension with the New Kirkham Suspension.
-One rear tire was mounted on a front wheel and one front tire on a rear wheel.
Front
Rear
Old suspension components.
New Smith's gauges installed in the old vinyl dash, which i eventually ended up replacing with new leather from Kirkham.
01-10-2012, 02:50 PM
AL
01-10-2012, 02:51 PM
AL
01-10-2012, 02:54 PM
AL
November 2010
New Steering Rack
Gorgeous new engine mounts from Kirkham.
Non functional sidepipes that were removed from the car.
MSD digital 6 Ignition Box mounted in place
01-10-2012, 02:58 PM
AL
01-10-2012, 03:01 PM
AL
01-10-2012, 03:18 PM
AL
March 2011
Engine being assembled at ProLine Racing in Georgia.
Edelbrock cylinder heads after being ported and having larger valves installed at Keith Craft.
Exhaust port
Intake Port
Before intake was port matched. The intake manifold ports matched up perfectly to the cylinder head ports before they were ported. This shows you why the edelbrock heads really need to be professionally ported.
01-10-2012, 03:20 PM
AL
01-10-2012, 03:26 PM
AL
April 2011 Continued
Stainless Steel Kirkham Fuel Tank
Sending unit
Tank installed
Emblems installed
Beautiful Kirkham Pulleys
Interior looking sharp.
Bellhousing surgery-removed 3/4" from the top as specified by the Kirkhams
Trimming the Quicktime bellhousing to clear the Kirkham clutch fork.
After
Upper and Intermediate steering installed
Fuel pump and pre filter installed.
01-10-2012, 03:29 PM
AL
01-10-2012, 03:32 PM
AL
01-10-2012, 03:36 PM
AL
July 2011
Finally got the panels back from the powdercoaters.
Before
After
01-10-2012, 03:39 PM
AL
01-10-2012, 03:43 PM
AL
August 2011 Continued
Prepping hood and scoop for the paint shop. The scoop was riveted in place with rivets that were too short, which decided to pull out one day when I was opening the hood by using the scoop. The scoop was installed prior to painting, so the paint peeled off of the hood with the scoop when the rivets failed.
New Button head bolts. Some will probably not like them, but i think they look good.
Sanded down and ready to go to the paint shop for more sanding, prep, and to have the stripes sprayed.
01-10-2012, 03:46 PM
AL
01-10-2012, 03:48 PM
AL
01-10-2012, 03:50 PM
AL
01-10-2012, 03:54 PM
AL
01-10-2012, 05:15 PM
Vic
How fitting that your 527 post was the completion of this thread, matching the beast under the hood
Simply beautiful
To be applauded - Well freaking done!!!
