Old 03-14-2013, 02:58 AM
Cobra Make, Engine: 1965 registered Brushed Kirkham polished stripes, 427 FE kieth craft 482 efi.ss chassis and all the go gear .
Default FE off centre ?...
Hi guys,
Unless I am going mad , is it normal for my FE to be off centred on my Kirkham ?
Cannot get the traditional oval air cleaner to sit right!
Thanks,
Soul.
" And them boys in them Chevy's,are going to say Pipes!!! Look at them pipes !!!- Bill Cosby 200MPH.
Old 03-14-2013, 03:11 AM
Senile Club Cobra Member
Yes,
The engine is offset on a 427 Cobra and the Kirkhams have replicated that also.
rick@autoventureusa.net
Old 03-14-2013, 05:30 AM
Danr55's Avatar
If my memory serves me correctly, the FE is offset to the right and tilted aft about 7 degrees.
Dan in Arizona
CCX3209
Old 03-14-2013, 05:54 AM
A98Coupe's Avatar
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Yes the 427 engine is offset in a Kirkham exactly the same as the original cars. Also, if you have an Aviad oil pan, you will notice that the 'wings' are different left & right to take account of the offset and keep the chassis tube to oil pan clearance the same each side.
Old 03-14-2013, 08:51 AM
You can always move the hole in your air cleaner to align it with the hood scoop!!!!
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 03-14-2013, 03:29 PM
Default Bizarre !
Thanks guys,
I was convinced body / chassis alignment was out !
So....
Why were the originals out of alignment ?? any ideas ??
Thanks,
Soul.
Old 03-14-2013, 03:45 PM
1985 CCX's Avatar
289's were also off center to the right.
Any guesses.....
Old 03-14-2013, 04:04 PM
A98Coupe's Avatar
It is purely down to the input pinion offset of the 4HU salisbury differential unit.
Old 03-14-2013, 05:01 PM
1985 CCX's Avatar
Hmmmmm nice response.........
Old 03-14-2013, 09:02 PM
Cobra Make, Engine: csx4163 full comp alu. body
Didn't they make a offset intake manifold called the sidewinder for 427 engine?
Old 03-15-2013, 12:08 AM
i am converting my hi tech to rhd , and if you do not keep the engine in the palce it was on the lhd cars , you get a terrible angle on the propshaft ujs. i know after 3 sets of engine mounts and loads of tinkering.The footboxes are also set out to accomodate the engine offset. Again in the rhd makes the steeruing and drivers footbox extremely tight.
I suppose that fitting a 351c has not made it any easier, as the starter is close to the frame rail.
Old 03-15-2013, 03:31 AM
How much is the offset?
Old 03-15-2013, 03:39 AM
I make it 40 mm or in pre dinosaur times 1.5 inches.
Soul.
